Leviticus
- Dec 15, 2014
In the music player app you will see all of the music in one place whether it is stored on the SD card or in internal storage.
You are talking about Sony's stock media player?
one..it will show the external SD card. unless you use program zx2 recommend to install...then from that program you can choose to use internal or external storage.
Sorry, but this isn't quite right. Once the player is linked to your computer, you can swipe down on the screen and access either internal storage or the SD card.
From the manual:
[System storage] is selected at the time of purchase.
You can switch the storage while your Walkman is connected to a computer. Swipe down the status bar at the top of the screen and tap [System storage selected] or [SD card selected] to put a checkmark in [System storage] or [SD card].
If you switch the storage while your Walkman is connected to a computer, the USB connection is lost. To connect the Walkman as USB storage again, swipe down the status bar and tap [Turn on USB storage] - [Turn on USB storage]. The storage ([System storage] or [SD card]) selected in the USB storage settings is recognized as USB storage and the USB connection is reestablished.
I always detect this hissing problem when I plug in my SE846 to the zx2. Is it just my unit, or everyone has this problem (even with other IEMs)?
I hear some hiss on my Shure Se530, and these old iem's are very hiss sensitive and will pick up any if it's there, I guess it's the old dance with output impedance, and I don't think anyone has meassured and mentioned it as yet?
It's not bad on my other iem's, and non existent on my headphones, but on low impedance high sensitivity iem's will have hiss with the zx2, it seems, it's the same story with the a10 series walkman as well.
I see. The hiss I heard goes away after afew seconds. Yous?
Also, I've heard that some others have experienced a similar hiss when pressing "next track". Is it true?
To the vast majority of people the hiss will go away in a few seconds and will be completely drowned out when music is playing. If you know what to listen for your can still hear it in quiet passages. I'm not sure this is a hearing sensitivity thing but more likely your ear needs to be "trained" to pick it up.
I'm in the US. Where do I buy this thing? I don't want one with volume limited due to region constraints.
Thx!
Sony US lists it on their site but no stock until May. Crutchfield also has them listed but is currently out of stock.
Thx!
