SONY NW-ZX2
Feb 25, 2015 at 7:00 PM Post #1,894 of 14,773
I take a couple of hours to boot up so 30 seconds is great for me.
Feb 25, 2015 at 7:24 PM Post #1,896 of 14,773
Anyone know how to correct the time? Mine is set three hours ahead for some reason and I find no way to change it.
within android, there is a automatic time and date setting, see if that is ticked, if yes, just untick, this will allow you to set your time.
Feb 25, 2015 at 8:25 PM Post #1,898 of 14,773
What trick is that?
Just the same trick on ZX1, just to disable the default sound tuning application.
Lower down the volume,
Go to Setting / Apps / ALL / Sound adjustment / then push "Disable"
Feb 25, 2015 at 9:36 PM Post #1,904 of 14,773
Could someone here be kind enough to answer this: Does the zx2 decode DSD natively or converts it to PCM? The Sony websites seem to not mention anything beside it being able to play the dsd codec. Thanks!
Feb 25, 2015 at 9:43 PM Post #1,905 of 14,773
OMG was listening to music and did the above and...
HOLY *%$#@&   the volume SPIKED immensely louder!!!
Turn it down **ALL THE WAY** before doing the above.
