gerelmx1986
Is there a big difference between Sony NWZ-A17 and NW-Z100 besides the internal storage?
Yeah ZX100 sounds way better than A17 in all aspects
Thanks Kelly. I wish I could use 200gb sd card on the ZX100. I have not read anywear that ZX100 would work properly.
I also use a 200gb card...works perfectly
it only flashes and then when it cannot longe keep going it shows a message low battery, please charge@gerelmx1986 : when the battery is running out, beside flashing, will it change to red color? Thanks
Sent from my iPhone using Tapatalk
I recently began using playlists for the first time, to solve the lack of composer views (classical music). I've created my playlists in Media go (Sonys software) and selected m3u8. But o haven't imported any yet
Cool. BTW, did import playlist? If so, what software do you use? I use dapper, but the playlist are not complete.
yes[COLOR=111111]you have the latest firmware?[/COLOR]
I'd say stick with the HD5 then.
Sent from my E6653 using Tapatalk
