Actually no, the problem was in the files, it happened only with a specific album. I'm still using teh same combination iems & cable and I never experienced the "pop" again.
Question for Dignis Midas case users. What are Your general thoughts on build and ergonomics? And one that bothers me most, what about feeling of physic buttons. Is it flawless? I'm finding those edging points on play/pause and volume+ buttons really helpfull to use it without looking at a dap.
The buttons on the naked unit are much easier to discern. With the case on I make a lot of wrong clicks. Like changing track instead of lowering volume. But the case is a keeper for me.
was demo'ing the unit plus the remote for a skeptic who owns a vinyl shop and first he listened to my dsf rips using balanced plus shure 1540 cans and his eyes were like saucers...then just using a headphone out to a tube amp and he was like how much is this ?! originally when he saw the hx500 (i got mine from a pawn shop for $150) he didn't think he was worth dealing with. i tried to explain DSD/DSEE and how it bit samples unlike anything out there and his eyes were glazed over...but you cannot fool the ears
at one point the unit was up on a table in his office area with the speakers facing the shop and he walked to the other end of the shop and pointed the remote and it worked and he was, wow, that works pretty far!
my complaint is that it is very soft and will pick up lots of dings and scratches, even when being gentle
button use is not "flawless"...you have to position it just right and it does take some pressure...i end up using the remote
what's weird, i bought mine via japan back in dec, changed it to international version, just updated it to 1.20 using the US tool and didn't lose my BT remote
You are correct, it is probably your adaptor that is the culprit here. Have a precaution to not use SE cable with a balance adaptor as it may short circuit your 1A amp. If you have balance 2.5/3.5mm balance cable to 4.4 then it is ok, but again better to re-terminate to have the clean output.
