Matrix Petka
Or a moon 430 HAD...
I know - hard decision it is waiting for you - which one to keep. When I am in such situation .... I keep both For some time at least
Some say that zx300 sound so close wm1a in balance. But I think wm1a is still king
so it's better to just get an adaptor instead of reterminating my cables ? is that what you say ?
would you rather reterminate or get an adaptor ?
Its true Sony Kimber 4.4 cable is weak. It has good bass, but it's so cloudy/hazy. What you can do is reterminate your Ref8 to 4.4 mm. Email Alo for retermination. I think I pay $20 with shipping fees. It's worth it. Performance up another level with 4.4 mm. What Iem are you using?Guys, any thoughts on the following?
So far im not overly impressed with the performance of my Sony/Kimber cable balanced vs Alo Ref 8 single ended on the 1Z. Most reviews etc. say that balanced is the way to go but I've got to be honest at the moment I'm finding the Sony/Kimber/balnaced combo a little meh when compared to the Alo Ref 8. Nothing wrong with it I just expected more based on what I've read. Im thinking the Sony/Kimber cable maybe the weak link in the chain rather than the 1Z balanced output?
I would really like to hear your thoughts, experiences on this. I would particularly like to hear what cables you would recommend as I am considering buying a upgraded balanced cable to really get the best out of the 1Z.
Album folder ÷ Mp3tag + Fanart ÷ Paint + Drag & Drop = Simplistic equation of perfected end result with no frustration & Headache.
Awesome. How large is the formatted capacity?FYI,
new 400GB sandisk microsd works
About 366Awesome. How large is the formatted capacity?
I can't live without the remote after i had it.
My WM1A is set to All Songs + random.
So depends on mood i will skip songs.
I had finished 2 battery since i bought it. I am on 3rd remote battery.
393,803,202,506 bytes (which is where the manufacturers get the "400GB"), which translates to 366 GB when u calculate how much this is in GB:
393803202506/1024=384575439.9 KB
384573439.9/1024=375559.9 MB
375559.9/1024=366.7 GB
This rule is true for *all* storage devices!!!!
