nc8000
Thanks!
Yep, that's the one I use and it is quite respectable at just playing records as well, but naturally not a top grade player
Thanks!
Damn!
agreeListening to WM1A and comparing to much larger DAP and DAC/AMP costing more than wm1a we are a fortunate generation to be able to experience such sound in such a size. Sure future can only get better (that is I hope it can) but could anyone imagine back in 2001 we would be able to get such a sound from such a device?
yes Sony players only support front cover, there are. Many options in the embedding of images on filesI found two albums I had copied over which didn't show any artwork after copying them to the Sony, despite looking fine on my computer, and figured out that it was because there were two image files embedded in each of the AIFF tracks. I was able to fix this by removing both albums, deleting all artwork on the computer's files for those albums, adding a single image to the tracks, and then recopying them to the Sony. I'm not sure if that's a common issue, but thought I'd post the information in case someone else has a similar problem.
Today, I learnt what true fear is, when I saw my dog holding a golden sony player in his mouth.
Luckily, it was protected by a silicon case and kept in a velvet pouch, and he is a small house dog....but i have no idea how many times he must have dropped it on the floor as he made his way out of the room with his stolen toy....
If he can lift the WM1Z, not such a small dog.Today, I learnt what true fear is, when I saw my dog holding a golden sony player in his mouth.
It's a shih tzu...they are quite small..thankfully
And it won't be the first time that he has wrecked audio stuff...he destroyed a westone W50.
I think I would personally be more concerned if any of its saliva seeped into an exposed crevice of your 1Z .
Hopefully not though...
