SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
Mindstorms
Formerly known as Midnstorms
- Oct 24, 2016
Thank you!There has been an update, which brings the DSEE HX AI function to both WM1A/Z+ and WM1A to 1Z mods.
The DSEE HX AI function replaces the "Standard" option from the DSEE HX effect type menu. This function is
present in devices like the NW-A55, or the DMP-Z1.
Official description:
DSEE HX (AI, or not) works only for CD quality audio, or lower. DSEE HX will not have an effect for audio with
a sampling frequency over 44.1kHz or 48kHz, like "24 bit/96kHz".
DSEE HX (both AI or the other options) also works with the Bluetooth receiver or the USB DAC functions.
You can "see" the function in action by switching the visualizer to "Spectrum Analyzer", and monitoring the "HIGH"
spectrum of the sound.
There are also some improvements to the integrated switcher, and all the languages were updated to reflect the
DSEE HX AI function replacing the "Standard" option of the DSEE HX effect type menu, as well as the "Switch Device
Model" replacing the "Factory Reset" function.
Do I need to first switch back to stock before installing this?
No. Like always, this works like any other firmware update. Just install it and that's it.
LINK
Main post link
Enjoy!
Ravenous
- Jan 6, 2011
whats DSEEHX AI ?
As far I as I can tell, it apparently "adds information" to the sound of the music you are listening to, essentially mimicking "high resolution" for standard resolution audio in 16/44.k format.
EDIT: Thanks Mr. Walkman, was too slow lol.
gerelmx1986
It did took like 2 or 4 minutes when I had everything crammed as 16/44.1 — e.g I converted all Hi-res and DSD as 16/44 on the walkman, but then as I got these DGG SHM-SACD I decided to transfer all over again as original resolutionThat’s pretty good. I thought it will take much longer when you change the card as the player needed to rebuild the database.
Anyway, one minor suggestion. I instead of storing the albums in the 3 cards by composer according to the alphabetical order, you may consider to group those favourite composers in the 1TB card. cheers.
flyer1
- May 18, 2009
He installed WM1A/Z+, and then he switched the model to 1A and that's it.
Usually I recommend installing the mod again, to make sure the 1A or 1Z sound tuning is properly set, but not doing that may result in some combination of 1Z sound and 1A sound or something like that. I didn't test it myself, but there is nothing wrong in doing it like this.
So only use model switcher after installing one of the mods (WM1A/Z+ or WM1A to 1Z). And if you'll want to switch back, first change the model back, and then apply the Back to Stock firmware.
This is what I prefer on my 1Z/EX1000. Switching to 1a but not installing the WM1A/Z+ again, gives me an excellent sonic experience, like a whole new world opened up! And even better than when I do install WM1A/Z+ again.
Also find myself keeping DSEE AI continuously on, it's like magic applied to all my normal FLAC files
Redcarmoose
I’m going to have to try. Cheers!
aceedburn
I discovered a new nirvana. WM1A to wm1z and model switched to 1z. This to me is the best I’m hearing right now. I can’t describe the feeling but I prefer it over WM1Az+. More natural, vocals more alive, bass deeper and more impactful, treble crystal clear yet smooth. Full rich mids with breathy vocals. A fuller and more dynamic sound.
Vitaly2017
And dsee hx AI enabled?
aceedburn
I’m listening through an amp so it’s always direct mode on. I only use DSEE HX AI when I’m using the Walkman direct with headphones.And dsee hx AI enabled?
- Jun 26, 2001
The one negative about any of the DSPs, as soon as you switch off source direct, no matter how they improve the sound, the background hiss is much easier to hear - even if all DSPs are disabled...And dsee hx AI enabled?
As good as HX AI is, on extended listening, I'd rather have inky blackness
aceedburn
Yes and easier on the battery as well with DSEE HX AI off. I’d only use it for older recordings like the 70s and 80’s rips I have. The newer jazz and vocal jazz recordings don’t really benefit much from it. But it does work very nicely and the sound difference is very discernible.The one negative about any of the DSPs, as soon as you switch off source direct, no matter how they improve the sound, the background hiss is much easier to hear - even if all DSPs are disabled...
proedros
do you have a typo or something ? if you are already to wm1z , how do you change to 1z ?
aceedburn
WM1A to wm1z is the firmware mod. And I changed my model to 1Z.do you have a typo or something ? if you are already to wm1z , how do you change to 1z ?
Do you reapply the firmware after switching model?I’m listening through an amp so it’s always direct mode on. I only use DSEE HX AI when I’m using the Walkman direct with headphones.
aceedburn
Yes after switching models i always reinstall the firmware as it loads the specific tuning for that model and will be more accurate. Without losing it you get a different sound but some like it that way too.Do you reapply the firmware after switching model?
- Status
Total: 15 (members: 0, guests: 15)
