SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Jul 24, 2020 at 11:09 AM Post #41,611 of 45,723
I’m listening through an amp so it’s always direct mode on. I only use DSEE HX AI when I’m using the Walkman direct with headphones.
The one negative about any of the DSPs, as soon as you switch off source direct, no matter how they improve the sound, the background hiss is much easier to hear - even if all DSPs are disabled...
As good as HX AI is, on extended listening, I'd rather have inky blackness
What I discovered is I like to use dsp on wm1a cause they add some warmer and more cozy sound.
On wm1z I dont like enabling the filters and stay direct source as maximum possible. 1z is already fully optimized and warm by nature, all dsp's only ruining it.
1a yes dsp
1z Nooo
Jul 24, 2020 at 11:24 AM Post #41,613 of 45,723
Yes after switching models i always reinstall the firmware as it loads the specific tuning for that model and will be more accurate. Without losing it you get a different sound but some like it that way too.
I believe this Wm1a to Wm1z doesn't have the same modification process applied to the system compared to Wm1az+
Jul 24, 2020 at 11:39 AM Post #41,614 of 45,723
The process is till the same for whichever firmware you use. Once you load the firmware it installs the tuning based on your device model. So if you’re on 1A it installs that tuning and if you’re on 1Z it install the 1Z tuning. So it’s always advisable to run the firmware again after switching models.
Jul 24, 2020 at 11:53 AM Post #41,615 of 45,723
Yes but on 1a you have 1a/1z+ and 1a to 1z! Then switched 1z.
It is 2 different tuning 1z+ and 1a to 1z
Jul 24, 2020 at 11:54 AM Post #41,616 of 45,723
WM1A to wm1z is the firmware mod. And I changed my model to 1Z.
ah i see , so there are even more variations that i thought...
excellenr.
Jul 24, 2020 at 12:18 PM Post #41,617 of 45,723
Here are all the possible combinations:
1A - Sony Stock firmware
1AZ - 1A switched to 1Z using "WM1A to 1Z (3.02) [IntegratedSwitcher].exe"
1A+ - 1A running 1AZ+ custom firmware using "WM1AZ+ (3.02) [IntegratedSwitcher].exe"
1AZ+ - 1A switched to 1Z running 1AZ+ custom firmware using "WM1AZ+ (3.02) [IntegratedSwitcher].exe"
I am slowing comparing all of these permutations against a stock 1A and a stock 1Z using Region J and will post my findings here. So, please me patient as it is time consuming.
Jul 24, 2020 at 12:20 PM Post #41,618 of 45,723
But it’s been said WM1AZ+ is not just a sound tune but a custom firmware so I assume the sound tuning parameters known and manipulated by some people over here when making his Fw tunings are untouched and the improvements in sound comes from changes in another area so the players sound different than with the stock fw. Am I right @MrWalkman ?
Jul 24, 2020 at 12:25 PM Post #41,619 of 45,723
Its a new fw that has sony sound. Not custom
With added dsee hx and improved battery life also faster ui navigation....
Jul 24, 2020 at 2:05 PM Post #41,625 of 45,723
Status
