TheThingGoesSkrrr
my unit drains it pretty fast. I charged it on sunday and i only have 50% left (5-6 hours of usage). Maybe i should do a battery reset after all the updates
Any idea how long 1A should last if you use it as bluetooth receiver?
17 to 18 hours for me
As BT receiver ?
Corny question, does anyone listen to their Walkman while it's charging on the PC or do you just let it fully charge before going at it again?
So I'm guessing it's fine to listen while it's charging? I'm perhaps being TOO careful with this new WalkmanI use mine mostly in the evening when I travel and sometimes also at home, I send 100-150 nights away from home each year
Looks great. What tubes are you using (curious because I see they all need adapters)?
Uh, oh... just got my RMT-NWS20 Remote Commander for the WM1A. But guess what? Isn't supported by the North America version.
Seems that I need the Asia/Australia/NZ (E) region set and then the "remote control setting" will appear in the Bluetooth menu.
I guess I will have to plunge into the world of changing the region on this player...
Is it better to buy it brand new?
