phonomat
- Jan 28, 2013
I am giving up altogether on leather cases. It seems that the edgecoating always fails.
Also, they make you look old.
They don't make you look old. I love my case and I've had a few.I am giving up altogether on leather cases. It seems that the edgecoating always fails.
I like your case too!
Has anyone compares the digital output of WM1A and WM1Z to an external DAC?
Does the WM1Z sound better than the 1A as a digital source? Going to use my WM1A’s digital output to my Hugo TT2 by USB output.
For Mac users .. looks like Os Catalina has screwed up Sony firmware update software . I am not able to upgrade or downgrade anymore. It just gets stuck on the "connect your device to continue" screen. I was able to do this just few weeks ago when I downgraded FW to1.02. Also just few hrs I updated another Mac which still has Mojave with latest security update. Now I can’t upgrade / downgrade on that machine as well. The installer kills itself when you connect wm1z to the Mac for upgrade . In both cases the software is mounting and loading,but failing to update. I suspect Mac OS X is tightening its security for unapproved developer apps even when I have given explicit permissions in the security settings. I however managed to update firmware using windows 10 (thanks for nc800 box link).. Catalina has been a pain so far
any Mac user has experienced this after patch upgrade. Please note I could do this easily before the upgrade or security patch
Thoughts?
Thoughts?
I use the XBA-Z5 with the 4.4mm kimber kable with my 1A. Match made in heaven for me. No amp needed. I use an amp for other cans.Hey guys,
Probably someone already asked but I need recommendations for headphones to use with the 1Z.
I have the Shure Se846 with the kimber cable 4.4 from Sony and it sounds quite good. But with my HD600s I have to use the volume at max and it is still not loud enough. I checked if my unit is capped with this pc program one can find on the web but apparently it is not capped. So I'm assuming that Sony lowering output power gets is part of having better battery life than other players and the usual cheekyness of wanting to sell their headphone amp. That being sad can anyone recommend top headphones that won't need as much power to drive as the Sennheisers?
Thanks and cheers
Hey guys,
Thanks and cheers
IER-Z1R and MDR-Z1RHey guys,
Thanks and cheers
Hey guys,
Thanks and cheers
