NaiveSound
- Nov 8, 2015
That oriolus thing supossadly hisses.... That's unfortunate, at least I can rule it out. 3.0 /1z is amazing at a micro hiss. Basically not there. Even with sensitive iems
I would encourage folks to try using the WM1a/z as a source line out. You can't break anything by doing it and all you risk is purchasing a cheap adapter cable. Please share your results.
First tentative not very conclusive: used the SE output of the WM1A wired into Jotunheim input (cable jack 3.5mm to RCA)
I compared the same track with the WM1 as source and the the Modi Multibit, on a Focal Clear (balanced output)
WM1A sounds dimmed (although volume on the DAC was set to 120), and super flat, without life, completely different from what I get directly from the output.
Not sure if the SE input to Balanced could mess thing up. I was just curious.
I'll try the single ended cable I got in the Clear box and see if it helps.
More tests soon.
More tests soon.
Never mix single ended and balanced, only single ended to single ended and balanced to balanced
You might also try hi gain output on your WM1a.
Definitely trust your own ears and what your wallet allows. Sony S Master HX digital amp, much like the Chord DAC products, combine the DA conversion and amplification into one chip. The volume controls all happen in the digital domain and has no bearing on the analog output. This is both energy efficient and very low distortion and noise.
Talking about low distortion, I have never seen any measurements for the Sony Walkmans 1A/1Z. They could only have a SNR of 85 for all we know, has someone personally measured jitter etc?
(Yes I know it doesn’t determine sound quality, but I’m still interested)
Same here! Love my 1Z as a source into other amps.For line out i do High Gain and maxed volume
More tests soon.
I took my favorite test your headphone playlist (mix of rock, indie and electro, all FLAC, some hires)
Test below all done in single ended mode.
1st session with the WM1A in DAC mode, wired into the Jot with jack-RCA cable
WM1A settings:
- Low gain
- volume to 120 on the DAC
Amp settings:
- 10 o'clock on the amp
2nd session with the internal multi-bit
9 o'clock on the amp, still wow effect, this combo gives me goose bump
3rd session with the Clear directly in the DAP
WM1A settings:
- Low gain
- volume to 60 on the DAC
Definitely better than in DAC mode with amp
Summary for this quick Single Ended test:
Modi Multibit module + Jot + Clear >> DAP - Clear > DAP in DAC mode + Jot amp + Clear
I tried, it helps matching the level of the internal DAC (almost) but the overall signature has nothing to do with the internal multibit DAC which is a much better combo with the Clear, crispy details, punchy, great separation.
In the office I tried to pair the DAP with my old Fidelio X1... it is definitely better than my existing DAC (Audio Engine D1), I am gonna sold it for this very reason
At my office I used the WM1A as DAC and Amp, no external amp, WM1A has no issue to move the X1 (30 ohms).So then you found it was 50/50? Out from the 1A was better than the D1 making a line level signal for the amp, but in other cases.......no?
Exactly......
Though to each his own. Best part is everyone likes the versatility of the Walkmans.
Totally agree on that, this little thing has so much potential now it can ruin ppl just on cable
I am really delighted Sony made this move, I too invite folks to try around, the 250 mW (vs. 60 mW) on the balanced output should make a big difference on line output.
I'll just leave this here:Interesting, a tube amp that is designed to work with Sony 4.4 balanced out, soon to be released, 415$... I might go for it for tube goodness
https://headfonics.com/2018/10/oriolus-b300s-review/
