SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Oct 14, 2018 at 9:50 PM Post #24,736 of 45,723
That 3.0 firmware has me considering the 1Z (BT receiver feature, yeah), I have always loved the Sony house sound and the price drop on the Z makes it a compelling option :)
I had dropped the WM1A because of the lack of this feature (yeah I do like streaming to discover music) a while back and recently got a ZX300 on a whim and I like it so much (actually very close to WM1A only warmer) I am itching for a 1Z. Anyone had a listen at both and how much of a gap is there?
I've ZX300A and WM1Z. I used to own WM1A and Premium plus K-mod WM1A. WM1Z is really good and has that right amount of warmth and body. The details, resolution and texture is significantly better in WM1Z.
I've the DX200Ti with AMP4 and AMP4S. They are on par with WM1A and slightly more holographic in DX200Ti+AMP4S.
To my ears, WM1Z is the best sounding of the lot.
Oct 14, 2018 at 10:41 PM Post #24,738 of 45,723
I agree the WM1Z is the best sounding Dap Sony has made.
Oct 14, 2018 at 10:45 PM Post #24,739 of 45,723
Well what is the most optimal charging I can do for my 1z for best longevity of the battery? I don't care if it's a slow or rapid charge I just want it to last 3 years
In Sony settings I charge my battery up to 90% not 100% to prolong longevity of the battery. I wish Sony didn’t have to create database everytime we turn it on. I set it to auto power off automatically in 1hr it turns off.
Oct 15, 2018 at 12:46 AM Post #24,740 of 45,723
Great, thanks!
So happy I found a good deal on a recent second hand 1Z unit :D
Oct 15, 2018 at 2:35 AM Post #24,741 of 45,723
I’ve never turned mine off in 1 1/2 years (except for the 3.0 crashes and the other fw updates), always leave it on. With my use that equates to charging the player once every week and I also only charge to 90%
Oct 15, 2018 at 3:12 AM Post #24,742 of 45,723
as the other poster said, i also do the charge to 90% but do not use auto power off. the standby mode of this DAP is super low energy and I often dont touch it for days only to come back to it and get a dozen+ hours of playtime
Oct 15, 2018 at 4:38 AM Post #24,743 of 45,723
This album Astronaut ape
"Flight 420 "with 1z 3.0 ( firmware + ex1000 SE sounds unbelievable just pure perfection, thank You Sony for SE improvement. 20181015_103425.jpg
Oct 15, 2018 at 4:47 AM Post #24,744 of 45,723
I've changed from 3.0 to 1.2 on my WM1A and woah there is a huge change in sound.
1.2 is warmer, thicker, more intimate, bass is rounded and has more oomph, highs are less refined and not as smooth.
3.0 is colder, has wider soundstage, harder and more controlled bass, more details.
Obviously there are features missing in 1.2 from newer firmwares and UI works slower and less fluid.
After the downgrade a had to reset all settings because some of the menus like equalizer wasn't correctly displayed but basically very painless procedure.
Oct 15, 2018 at 5:52 AM Post #24,745 of 45,723
did you try 2.0 ? looks like it's the golden balance between warm 1.2 and cold 3.0
Oct 15, 2018 at 6:05 AM Post #24,746 of 45,723
Oct 15, 2018 at 6:33 AM Post #24,748 of 45,723
Yes, I'm at 2.0 at the moment and it appears to be a mix of both worlds. It has some the warmth of the 1.2, bigger soundstage, smoother highs but it's got less clarity then 3.0.
3.0 is the clearest, has the most detail, the biggest soundstage but it also is the coldest. 2.0 looses some clarity to keep the warmth.
Oct 15, 2018 at 6:39 AM Post #24,749 of 45,723
When you say cold 3.0, that's by WM1Z intital firmware standards?
I just acquired the 1Z and will get it soon, I need the features of 3.0 and I want smooth warm organic signature :p
Status
