- Mar 5, 2012
1. Search bar
Make it happen Sony
Feedback sent to WM designer.
I made a short video on v3.0. I like that it displays artwork for my .WAV files now.
1. Search bar
Make it happen Sony
I've changed from 3.0 to 1.2 on my WM1A and woah there is a huge change in sound.
1.2 is warmer, thicker, more intimate, bass is rounded and has more oomph, highs are less refined and not as smooth.
3.0 is colder, has wider soundstage, harder and more controlled bass, more details.
That’s a good suggestion please write to Sony support.1. Search bar
2. Read file meta in the background so I can browse in folder view immediately after inserting a new micro sd card. Similar to how AK does it.
Make it happen Sony
Small team, limited resources, tight deadlines, too much management.Search bar... I wonder why not yet.... We have to wait a year?
Are you using "Direct" mode in both firmware comparison?
I like direct mode with 2.0 but not with 3.0 I use EQ settings on my WM1Z to get the best slam bass I’ve heard.Yes, i've compared only in direct mode.
I suppose it depends on the genre you listen to & Headphones. What genres do you listen to.I only EQ the Noble Encore with the 1Z; everything else I leave in direct mode.
Noble Encore
Treble -4
Midrange -4
Bass +4
Already removed the volume cap off my player but a friend is trying to do his following my written method and the player keeps coming up as device not found any ideas ?
No that has been checkIt might be that it has a different drive letter than yours did
