That's what I thought. i'm confused about what happened then. I'm deleting all the files and starting over. I have been having issues with my cover.jpg files not showing for some albums (I think it's an interlacing problem).
Ok. The fresh transfer directly through the finder to the [music] folder worked. I’m still having trouble with the cover art not showing. Next problem to solve. At some point I’ll get to listening to music. Lol
If someone can help : Is there any SQ difference between E and E2 region / destination through rockbox ? I see that many choose E2 but only E has the remote control option, and i wonder if.... you get it
That’s what I figured based on my reading. Now I need to figure out how to batch convert all my cover art from progressive to baseline... anyone on a Mac have any ideas? I can use windows or Linux, too, but I’d prefer to use the Mac.
Finally got to hear some difference between DC phase linearizer OFF vs ON, the bass more tight and punchier and more runbly, more warm sound.
also using DSEE strings, these two settings give a nice more holographic sound too (recording too has this kind of feeling so it expands it beyond "out of head" experience), Philips Mozart edition is better than the new 225 from Deutsche gramophon in terms of SQ and mastering quality (i kept some discs from the DG edition but not that many, only new pieces or alternative performances i often sought)
Wow I have the Mozart 225 edition, it sounds so sweet on the Sony WM1Z. Yes turning EQ on using all the settings upscales the music to sound better. But it can also depend on how it’s mastered. The Bonnie Tyler remixes & rarities is an bright recording. Not even EQ turned on helps to tone down the treble sparkle. Rock music is the most difficult to EQ correctly
This is on the Mac version. I don’t know if windows is the same. There a little disclosure triangle in the bottom right corner of the small window. Click that and you’ll see it under the automatic transfer tab.
Oh okay thanks so it can still be sorted in folders as that’s how I have it set up as I have an very large music library. You’ll be surprised on how many songs are in my library about 2.3TB is 85,000 songs.
A transportable all-in-one DAC/player sounds interesting, if only to see what Sony manages to crams inside it as extreme miniaturisation of components that is never been done before is usually what justifies Sony's price tag for the most part.
