torifile
- Sep 7, 2005
There’s actually an automatic setting and yoon can even set it to watch a folder.Content transfer is manual transfer
Much like MusicBee, constantly monitor a Folder for changes. and you can even set it to transfer specific playlists or "Inbox" for new songs. Long story shorter: MusicBee is customizable as screwThere’s actually an automatic setting and yoon can even set it to watch a folder.
Nope, also you can sync foldersWhat the heck is going on with my music transfers? I have my music folder on my computer organized into folders and when I look at the Music folder on the DAP, it's all one big list with no directories at all. Is that how it's supposed to be? Just a flat folder?
Yup media go transferred with Artist Name\Album\TracksYes it’s supposed to look like that but mine is organised under artist name
*This is how Sony MediaGo transferred Artist folder structure, however i have my structure as Composer\Album\<Tracks>
That's what I thought. i'm confused about what happened then. I'm deleting all the files and starting over. I have been having issues with my cover.jpg files not showing for some albums (I think it's an interlacing problem).Nope, also you can sync folders
This is on the Mac version. I don’t know if windows is the same. There a little disclosure triangle in the bottom right corner of the small window. Click that and you’ll see it under the automatic transfer tab.Where is the automatic setting for this feature.
I usually manually transfer without MediaGo I drag & drop transfer is easier.
Depends on if it’s a bridge-tied load balanced circuit, where you are effectively getting twice the power or something like an active ground control balanced circuit where it’s closer to 50% more power.Yes, you will. Balanced out is always 2X the power in comparison. If you put all sound performances aside. Coincidently, better power is also better performances.
If you don’t care about sound performances, grab a cheap cables and have better power, at least
