Quadfather
does the WM1A/Z support such card?
Yes indeed. I am using one now.
No, leave the box checked. There is more than enough battery life at 90% anyways. Only charging to 90% extends the battery life. This option is also found on PCs, and other devices.Is this meaning to unmark box charge until 90% so it's fully charging to 100%. Doing opposite as sony says?
Dignis case owners. I hear you can’t fit on a case on if you have tempered glass screen for protection. Is this true? Or is the fit too tight
When checked, do we just charge the unit to full, which is equal to 90%.
Absolutely no, the wm1 fit perfectly with the glass screen on.
And you can easily slide the case out and back in without a problem? Case fit is very tight, I'm worried it will lift the glass screen protector up when sliding in.
No issue there. And by the way, I have a spare Dignis for saleDignis case owners. I hear you can’t fit on a case on if you have tempered glass screen for protection. Is this true? Or is the fit too tight
Wonderful! Does the WM1A drive the 800S well? I have yet to try because I don't have a balanced 4.4mm cable for it yet.My new Christmas toy to play with WM1A
I’d think 800S is more suited for 1Z than 1A, given the 1Z has more warmth and less articulation than 1A?Wonderful! Does the WM1A drive the 800S well? I have yet to try because I don't have a balanced 4.4mm cable for it yet.
SE output lack a bit of power. Balanced - strong enough to drive properly. HD800 S passed first stage of moding - internal wires changed to silver (original one tooo thin), custom made leather earpads with perfect seal and positioning, modificated acousting chamber to minimize vibrations and distortion. Stage II coming soon.Wonderful! Does the WM1A drive the 800S well? I have yet to try because I don't have a balanced 4.4mm cable for it yet.
