SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Jan 3, 2018 at 10:22 PM Post #17,762 of 45,723
I have some really great players considered higher end, but when I put my Sony NW WM1A into my listening rotation and get wowed. Such beautiful presentation.
Jan 4, 2018 at 4:14 AM Post #17,763 of 45,723
Can you comment on sound changes eg treble, mids, bass, clarity, resolution, dynamics etc?
Upon AB the old unit, the mod unit is much better on clarity without "thining" the sound. You probably familiar with how the stock unit sounds on the bass. The mod clear up the "fog" and the bass goes much deeper and tighter. I have the Audio 64 A18, it now sounds much more neutral. Overall, it brings a cleaner and more dynamic sound.
Jan 4, 2018 at 6:34 AM Post #17,764 of 45,723
1Z > Effect Audio Lionhart balanced > 64 Audio A18
I had the opportunity to have for about a week two WM1Z units that each had slightly over 200 hours on them. I loaded 1.2 on one unit and 2.0 on the other. Then I compared the sound using multiple tracks at the same volume. In the end, I decided to stick with 2.0. To me, it has better layering of the sound and greater soundstage. I could hear individual instruments more clearly. It is a bit more reference sounding than 1.2, but for my tastes, I like that. I found 1.2 to be a bit too dark and a little bit congested compared to 2.0.
Yes I agree I changed back to 2.0v as on my Sony WM1Z I has over 425hrs burn in, I use direct source it has enough bass for songs that need it. 3D soundstage & depth as when I turn on EQ it has deeper bigger bass, that I switch back to direct source turn up volume to 50-55, will prolong battery life. Direct source sounds better with 2.0v has more resolution & instrument separation.
Jan 4, 2018 at 11:39 AM Post #17,767 of 45,723
Jan 4, 2018 at 11:43 AM Post #17,768 of 45,723
I bet cables do make a difference, while my z5 cables don't arrive yet, but I can attest this because my mdr-z7 have the z1r cables... Xba-z5 with stock cables sound less resolving and smaller Soundstage than the MDR-Z7 with z1r cables, z7 sound resolving, big spacious stage.
Jan 4, 2018 at 12:03 PM Post #17,769 of 45,723
Sony Kimber Cables for Z5 makes the player sound stunning. I bought an XBA-A2 also for more casual use and need to get one kimber for that. I have had the Z5 from release but I need to prolong its life with the A2
Jan 4, 2018 at 1:07 PM Post #17,772 of 45,723
I feel xba-z5 want to go e more performance out of my WM1A but are bottlenecked by the stock cables, hope my MUC-M12SNB1 arrives soon
Jan 4, 2018 at 3:48 PM Post #17,773 of 45,723
About 30 hours in on my 1z listening on balanced with Z5's I just went back from FW2.0 to 1.2.
I noticed quicker listening fatigue on 2.0 and while it is more detailed somehow missing some 'fun' in its sound signature. Maybe the extra detail and seperation tires me and makes me overanalyse its sound. Direct source I often didn't like on 2.0 but is always great for me on 1.2. Guess I am a bit of a basshead as well..
Jan 4, 2018 at 4:32 PM Post #17,774 of 45,723
probably a dumb question
my wm1a shut down as i was listening (battery drained out)
does it need some charging up before being put back on ?
i press the power key after charging it for 5 minutes but i get nothing
what gives ?
edit : nvm , after charging some more it came back to life hurrah
Jan 4, 2018 at 5:14 PM Post #17,775 of 45,723
what gives ?
yes when it shuts down due to low battery for me after some 10 minutes it comes back to life.
One word of caution, don't drain your battery to shutdown too often otherwise you will kill it sooner, ich argentino when it has either one bar left or flashing icon, tho I let it drain to zero once every two or once every month
Status
