Other Select DAP Comparisons
I'm more of a desktop user thus I own very few DAPs at this sort of TOTL level and to be frank the LPG is the only one I feel is directly comparable to the WM1Z out of what I own - both being no compromise pure music players. Nevertheless there are still a select few DAPs I'd like to draw comparisons to as they contrast/share similarities to the WM1Z and I feel may still be interesting propositions depending on what one might be looking for. Pricing is pitched more at the WM1A price levels. None of these offer balanced output and all units, to save repeating each time, run warm, battery life is between 8-12hrs and I don't use an EQ:
Acoustic Research AR-M2:; There is one thing in particular I don't like about the M2 which is it's large volume control location which is on a corner at the bottom; perfect for accidentally destroying ears. It's also a large unit but slightly unweildy compared to the WM1Z being a very thick, large angular mobile phone shape. Also only a single MicroSD slot with 64Gb internal memory, nevertheless build quality is top-notch.
M2 has more power to hand, it's the only DAP I own which seems to have more power than the LPG. Soundwise the M2 has the most potent bass of any of the DAPs I'll mention here but also lacks some of the resolution in those low frequencies. Layering capabilities of the WM1Z are well ahead. Mids aren't quite as rich as the Sony. Highs are currently a bit more vivid but that might change with time. The M2 can sound a little grainy at times but extremely powerful, energetic and visceral. Overall the WM1Z is a more mature sounding, more resolute package.
What the AR-M2 has got going for it is that it's an android based device with wifi and bluetooth. Caveat being it's not a full Android firmware but bar Google Music (because of there being no Google Services) I've been able to sideload most other streaming apps onto the AR-M2. If streaming is a must and preference is for a warm but less analog sound, or one were a basshead looking to make the transition to a more reference package this is worth looking at. The amp is too powerful for decent control on many of my IEMs except the least sensitive ones but it is the only portable I own which can just drive my Abyss AB-1266 if you're looking to drive hard to drive headphones without an external amp
Soundaware M1 Pro: I mention this here because despite being a far cheaper unit, I feel out of all the DAPs I own this is the one which shares the closest sound characteristics, specifically to the WM1Z (rather than the WM1A). It has an FPGA dac which is designed to sound more warm and analog. It is, confusingly, a mixture of the presentation of two other units; the M1 (Digital) and M1 Analog... specifically the soundstage width of the digital with the warmth and 'roundness' of the Analog. Build quality is a mixed bag with a solid body marred by a very poor MicroSD card cover and a somewhat odd button configuration. I've even got a large piece of dust under my glass screen, which is something I've never encountered before in any unit, no matter the cost. The unit does, however, have dual MicroSD slots. The worst thing about the unit is the UI which isn't buggy but just poorly thought out. If you're used to those odd boutique DAP UIs and can live with that, it's a very unique offering but hopefully SoundAware will just tweak the UI with firmware revisions. Size wize the M1Pro is far smaller, far more pocketable. We are speaking about completely different levels of quality between the Sony and SoundAware but then they're different prices.
Soundwise it also has a warm liquid like presentation. Detail levels are superb despite that warmth but micro-details are just not up to the levels of the WM1Z. Currently both units exhibit a polite presentation to their high frequencies so you won't encounter harshness but the mids of the WM1Z are still richer and more emotive. Soundstage is about the same in width but not quite as layered in depth. In the same way that the WM1Z has the same level of detail retrieval as the WM1A but in a thicker sounding package, the M1Pro has an almost as resolute but even more rounded presentation than the WM1Z. Where the Soundaware really excels is as a line-level source/transport as the output is extremely clean and musical and to that extent it seems even cleaner than using the WM1Z as a line-out.
As a source for the Shure KSE1500 I was hoping that the WM1Z would be a beautiful pairing but possibly because it's not burnt-in properly it just sounds a little flat compared to some other sources. I know few people will hear it but the M1Pro really does excel with the KSE1500, which (for my preferences) can be a little harsh and unforgiving with certain other sources. It's size as a nice stack also helps here and because of that I can't see myself using the WM1Z with the KSE1500 as it will just be too unwieldy even if the sound improves overtime.
Questyle QP1r I absolutely hate the scrollwheel on this unit. Considering the level being pitched at the choice of mechanism here is diabolical but there you go. The other thing I do not like is the recessed micro-USB socket. Internal memory is 32Gb but there are Dual MicroSD slots. The UI is quite nice, clean does the job and build quality (bar the wheel) is excellent.
Sound wise, this is an interesting comparison as this is where I feel personal preference come into play. Compared to the WM1Z the Questyle is not as warm sounding and has a slightly more analytical presentation with less weight thus more air. In that respect it occaisionally seems faster than the WM1Z. Despite my saying that the WM1Z doesn't lack detail, with the QP1r it's easier to pinpoint certain instruments because of that perceived clarity. If you're less into a sweet presentation and more into separation and pure clarity, I can see the QP1r being more appealing. Bass isn't thin by any means, it's just tight, controlled and fast but still, less in terms of volume, compared to the WM1Z. Mids aren't conveyed as emotionally as with the WM1Z but they are clear, distinct and equally front. The usual pre-burn-in story with the highs which are wonderfully balanced on the QP1r. Soundstage is about equally wide and there is good depth to its presentation while lacking some of the weight of the WM1Z.
So for the most part I preferred the LPG with my headphones to the QP1r. The same remains true here with my preferring the WM1Z with the majority of headphones I've compared. IEMs is a different story and what I've found is that with particularly denser sounding IEMs I do prefer the QP1r. Initially I had the JH Audio Layla paired with the WM1Z; with the pots turned down to the 9pm position the Laylas have the largest soundstage and depth of any IEM I own. Paired with the WM1Z it made for the most 'out of the head' synergy I've had from the Laylas. Now the Laylas are/were tuned for use with A&K DAPs which as has been pointed out, a different kind of tuning to the WM1Z, the Laylas are a very full sounding IEM compared to others and paired with the WM1Z it can just sound a little heavy. It's not outright bad but there's a slight lack lightness and separation and the thing which suffers the most are the mids which lack some clarity. Even with the bass pots turned down the 4xlow drivers seemingly receiving far more emphasis than the 4xhighs. For very large symphonic pieces, despite the large soundstage, it can sound a bit congested and here the QP1r's more airy presentation makes for a far stronger pairing.
