update: It seems like the a55 needs time to process. I can delete some songs from the top of the list now
Sony NW-A50 Series
FinancialWar
- Feb 14, 2013
I bought a "brand new" off ebay that was made in 2018 that had missing wrapping.
There is skipping issue when connected to both Bose qc35 and sony 1000XM3, especially when riding bike.
is this a normal issue or did I get a lemon?
- Nov 28, 2016
change the BT settings and see if that helps
Any recommedation to improve SQ?
What option to turn on and off?
Mine are
DC Phase, Vinyl - On
The rest are Off
Mine are
The rest are Off
homesickmadmax
I prefer The A50Z (classic) mode with the clear audio+ ON when I really want my music to be alive. Otherwise, A50Z (classic) with DSEE HX and Vinyl ON only.Any recommedation to improve SQ?
Mine are
The rest are Off
- Nov 28, 2016
After much toing and froing I think I've finally settled on the A50R FE - not so much for the differences of sound but for the features it has. Btw I'm mainly using direct on.
The battery is crazy on the A50 - after flashing several times, I thought it to be a good idea to recalibrate the battery, so I ran it down till empty. With just one bar left, it was still going on for 6 more hours or so!
Also I solved my only peeve, how the screen just collects fingerprints. The clear screen protecting film I had laying around helped just a bit. I finally find a matte (non reflecting) film that's for the A30, but works just as well on this - boom, prints gone and the DAP looks even cooler, just a black slab. best 3€ spent on this hobby![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
supersonic395
- Oct 3, 2015
The battery life while using Bluetooth is disappointing - it drains much faster than my previous nwzx100 ![Thinking face :thinking: 🤔](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f914.png)
Gamerlingual
So when using this as a Bluetooth transmitter from Windows, does it output LDAC?
FinancialWar
- Feb 14, 2013
is there a way to show time on the A55?
Gamerlingual
https://helpguide.sony.net/dmp/nwa50/v1/en/contents/TP0002342897.html
The player does not display a clock. The clock setting is used for data management.
- Nov 28, 2016
This is one of those very weird Japanese design things. You can even set the clock display style (dd/mm/yyyy or mm/dd/yyyy or yyyy/mm/dd) while the clock is not displayed anywhere.
Thinking about flashing Mr Walkman fw.
Any issue with the battery or other functions guys?
Also, for a vocal lover, which one should I chóose?
Just install dmp and the sound is incredible
Also changed the walkman to J region but then there are some weird setting (recording)
Can I disable it?
Can I disable it?
- Nov 28, 2016
Can I disable it?
It's baked in the J setting
haha thanksIt's baked in the J setting
Still amazed by the sound. Cant believe the A55 can perform this good.
