Dec 30, 2024 at 5:32 PM Post #2,447 of 2,476
@unknown321123 I just finished reading your -Making Of document: what a facinating and insightful piece. Many thanks and congratulations for your work.
I will certainly give Wampy a try even.
Jan 9, 2025 at 6:22 AM Post #2,449 of 2,476
I purchased a used 1000X3 in great condition. LDAC sounds good. Much better than my AirPod’s Pro 2.
Jan 10, 2025 at 4:55 AM Post #2,450 of 2,476
are you happy with the battery life? Have you had the possibility to test it before buying ?
Jan 10, 2025 at 10:25 AM Post #2,451 of 2,476
No I blindly bought it. I charged it once since I got it back in early November. Hasn’t died yet.
Feb 19, 2025 at 12:18 AM Post #2,453 of 2,476
Hi, in pre-Mr. Walkman's-WalkmanOne times the region destination tool (https://www.rockbox.org/wiki/SonyNWDestTool.html) was used for changing regions.
If your NW-A55 is currently on CEW2 region, putting WalkmanOne for NW-A50 series (https://www.mrwalkman.com/p/walkman-one-a50series.html?m=1) on it should remove the volume cap without applying the Rockbox destination tool before.
Applying WalkmanOne on NW-A55 turns it into a little beast. I especially like the NW-WM1Z tuning. So my recommendation is - definitely go ahead with WalkmanOne.
Feb 19, 2025 at 12:29 AM Post #2,455 of 2,476
Go to the main page of MrWalkman. In the headline bar there are links to Walkman NW Series for which WalkmanOne is available. NW-A30 Series is among them.
Feb 19, 2025 at 6:30 AM Post #2,457 of 2,476
is this compatible with the NW-A35?
Yes, and it definitely offers a smoother UI compared to the stock firmware.
Also take a look at Wampy, developed by @unknown321123, which for A30 is only available with the Walkman One firmware: https://github.com/unknown321/wampy
It offers the Android cassette background for when playing music (or a Winamp-like screen) as well as many other options - read all about it in the link above.
Feb 19, 2025 at 6:41 AM Post #2,458 of 2,476
thanks @jeejack and @MrWalkman its my Dads DAP, not sure if he’d be into changing it around but i’ll certainly look into it and ask him.
