Is the remote in the picture sold separately? If so, does anyone know where to get one? Or is it a brand new item?
Thanks.
Thanks.
Thanks.
Thanks.
So I would guess based on previous history it will be about $450.00 and $550.00 CAN respectively. Not sure I would want to pay that much for this DAP if pricing holds considering my A17 was only $279.00 with 64 GB of internal memory. Especially if the internal components are the same as the previous model. I hope they will at least put the higher quality capacitors found in the ZX100 into this one to up the power output a little and improve the sound quality.
Explain to me how a difference of 16 GB of internal memory justifies a $100.00 price difference? Your talking about a couple of bucks difference here between a 16 GB and 32 GB storage chip. Way to gouge your customers Sony, that's like a 98% percent profit margin on the $100.00 difference. I would hate to see how much they would want for an A37 with 64 GB on memory.
Not sure the quality of the earbuds, but the $100 covers that as as well. So you get memory+ color matching earbuds (quality unknown as of now)
If the A30 can output DSD and the Mojo can recognize it, that would make for a killer little combo!
That is correct, Sony no longer wants to make android based DAP's so the ZX2 will stop being sold once the current market supply runs out. Then the WM-1A will officially take its place.
The New DAPs are Android-based (though there's no literature stating what version).
One-piece cables for Mojo from China cost only 25 bucks (160 RMB) a pop
Here are some pictures with previous A Series Walkman and Mojo in action
I thought it was one model MH1 was android and the other was walkman, but maybe I misread on that thread.
I hope its the cheaper one because Walkman OS is by far best DAP interface I have used. Really like A30's combo of touchscreen and buttons as well.
Oh those are a big improvement, thanks! Hopefully unlike A10, A30 can control OTG volume for those of us w/ dac/amps that have no volume adjustment.
That was the initial speculation but it has now been confirmed that even the $3200.00 1Z has the Sony OS and thus no wifi and streaming audio. I shake my head at people considering the 1Z consider it is missing modern features like wifi and streaming audio.
Ah, that's a bummer for the Android using Sony fans- I was thinking it would be like how iBasso is splitting the difference with their upcoming dx120 and dx200, one will be full android connectivity the other will be more basic. Fortunately there's no shortage of Android DAP! Personally am glad there are alternatives though- don't like using Android/iOS, don't wifi or stream on DAP.
Other than OTG volume master I hope the A30 also has improved output power over predecessor like MH1, though seems doubtful, because Sony
