Fiio L27? If you are in Europe, on Amazon italy is available from december.Did I imagine fiio bringing out a new sony lod cable?
Seems its digital out to micro usb and still out of stock!
SONY NW-A30 SERIES
- Nov 28, 2016
Thanks but those are discontinued and not available, that's the problem im having
Sorry, my bad, didn't notice the "discontinued" mark
- Nov 28, 2016
I grabbed it in Singapore in the Adelphi center (it's full of audiophile stores, can't remember which one had it)
springbay
I got the L27 from my local FiiO dealer around New Years, and it works great for stacking the NW-A35 with the Q1 MKII as well as the Q5.
My local dealer -> https://www.mobileztore.se/product.html/fiio-l27-wmport-til-micro-usb-sony-kompatibel?category_id=9
John 90125
- Feb 22, 2017
Does anyone know if a 400Gb microSd card will work with the A35?
Jonathan-Mac
- Feb 7, 2017
I think someone said that a 200gb card worked, and that's above the stated max of 128gb. My card is 128 and works fine, the only problem is the more music you have, the longer the player takes to start up, as it catalogues all the files every time the player is started.
superuser1
I did use a 200 gb card on the A35 for a while without any problems.
docholliday
- Mar 14, 2017
Works fine...I have two of them in useDoes anyone know if a 400Gb microSd card will work with the A35?
John 90125
- Feb 22, 2017
Thanks for the info, I'm using a 200Gb card, but I have reached the stage I have to delete files to add new ones, so an update is on the cards.Works fine...I have two of them in use
docholliday
- Mar 14, 2017
Theoretically, the A35/45 will handle any card up to the limit of the file system. The reason that marketing originally put a limit is usually because that is the largest card available at the time of release, so to be safe, they only "certify" that a device will handle a certain size so they don't get accused of false advertising.Thanks for the info, I'm using a 200Gb card, but I have reached the stage I have to delete files to add new ones, so an update is on the cards.
I'll say that the 400gb cards aren't as fast...going from a 256GB Extreme "back" to a 400GB Ultra was kinda painful. There are faster 400GB cards coming out, but at present, the Ultra isn't the most responsive card. You'll notice a bit more lag when scrolling through the interface, especially as the 400GB gets filled up.
Hi guys, anybody used A-35 with Sony PHA-1A, how it will be sound compare with Fiio Q1Mark ||, or Q5?
superuser1
@superuser1 ... Looks about the same size ... How does it sound ? ... compared to the A35 on it's own ?
superuser1
Bloody damn good to be honest. way better than i expected. Very musical however not the most mature sound. I briefly listen to it with the ibasso it01 on balanced, great pairing.@superuser1 ... Looks about the same size ... How does it sound ? ... compared to the A35 on it's own ?
James McGregor
- Jan 5, 2016
Yeah that's digital out, your using the Sony as a transport there, I'm hoping to use the line out to let the Sony do the processingA35 --> L 27 --> Q1 Mk II
