I finally got them and love the sound on these things, great bass comparable to the xb500 but a lot better highs and mids. I love the controls and Bluetooth everything works flawless, definite upgrade.
Where they are falling short for me though is on comfort, while the pads feel good they clamp down so hard on my head. I feel some head/neck fatigue after just a half hour or so whereas the xb500 I could sleep in them. I don't want to but I might have to take them back because of this. Any suggestions on stretching them out without damaging them? Should they stretch on their own over time?
I'm pretty bummed as I like everything else about them.
Glad to hear you like them....at least from an audio point of view!
Did you check out the mods I mentioned in my last reply? Definitely worth looking into!
It's a shame you find them uncomfortable as I find them the most comfortable by a long way out of all the ones I've tried....and I've tried quite a few!
I do have a relatively small head though and as DCY77 says, the more you extend the headband the tighter they get!
I personally would try stretching them as I can't see it causing any damage...all that might happen is that the metal bends slightly where it meets the plastic, but even if it did it would be a small price to pay in order that you get to keep such a fantastic pair of cans!
As I mentioned in my
Comparisons , the only other Bluetooth cans which are pretty close in bass quantity are the Logitech UE9000's, the Philips Fidelio M2BT and my recently tested Denon AH-GC20's but non of them compare in comfort to the XB950's!
The UE9000's are very heavy, have an uncomfortable rubber headband and the earcups aren't very soft and are of a poor shape causing pressure to the lower part of the ear!
The Fidelio's are 'On Ear' and whilst they are relatively comfortable for 'On Ear' they don't compare to 'Over Ear' and will cause discomfort over prolonged periods!
The Denon's are pretty comfy, with very soft earcups like the XB950's but even I found them to clamp quite tight so they'd be even worse for you!
I'm sure you'll be able to stretch the XB950's or they may even become more comfortable over time?....then you'll have one of the most comfortable, bassiest bluetooth cans around!
