livewire
- Aug 13, 2010
I'm seriously considering snapping up a pair of these before they're all permanently gone. Also because they seem like a cool pair of cans to have generally.
^^^ DEW EET !!!
Has anyone both the 7506 (or V6) and the Beyer DT250 and could please compare them briefly?
I have had both but not at the same time (7506 and 80-ohm, resp.)
7506: More sub- and mid-bass. Colder low-mids. Brighter, clearer high-mids. More treble. Sound like closed Grados with bass. Overall best for speed, clarity, and upper mids (female voices).
DT250-80: More upper bass. Much warmer low mids. Slightly recessed (or smooth/muffled depending on POV) upper mids and treble. Sound like closed Sennheiser 6xx. Overall best for laid-back sound and low-mids (male voices).
EDIT1: The above descriptions are meant as comparative attributes and not absolutes.
EDIT2: I currently own 7506's with DT250 pads (best of both worlds, IMO, and sold the DT250-80 if that helps. Also, The DT250-250 is supposed to be less dark, more clear than the 80-ohm flavor. The Beyers are much less sensitlve than the Sonys and didn't sound as good through my iPhone. I would love to hear a properly amped DT250-250 to compare.
Oh man, thanks a lot!
That's a very clear comparison.
I own the DT 250 - 250 ohms and drive them with an ODAC+O2.
They sound indeed clearer and cleaner than the 80 ohms. They are so neutral and musical... Closed HPs of the highest calibre. Some people state they sound like a closed HD 600 would sound.
Since, like the Sonys, they are used in so many studios, I was wondering if the 7506 would be an upgrade, sidegrade or downgrade?
Thanks u again.
Amazon is pretty safe.
Don't forget Bluecell pads.
http://www.amazon.com/Bluecell-Replacement-Earpad-MDR-7506-Headphones/dp/B007XPMFGM/ref=sr_1_7?ie=UTF8&qid=1378472587&sr=8-7&keywords=mdr-v6
You can get pads from ebay for very cheap. There's some good pads and some really bad ones though, so be careful on which you get. A thread of mine on the subject: http://www.head-fi.org/t/672641/anyone-tried-sony-v6-ebay-leather-pads#post_9728748
Repairing the wiring really shouldn't be that hard, and if you know anyone who's ever used a soldering iron and isn't a total cluts, they very well could be able to repair them. If you're about to throw them away anyhow, nothing to lose!
