sid311
- Sep 28, 2005
Burn In Update: 50+ hours
The Upside:
The main initial noticeable flaw with these phones was the sibilance. I'm happy to announce that this has subsided and is no longer present. Mids are lush and utterly delicious. Bass has seemingly decreased in amount but is there when it needs to be. I would describe the bass as very accurate and controlled. This is probably due to the fact that I removed the foam dampening material in the tubes, which I later replaced with cotten. This had the result of slightly decreasing bass while bringing the mids slightly more forward. I might experiment with this more at some point. Detail and resolution are both excellent, I'm hearing nuances in music that I hadn't noticed with my E500s. Left/right separation has gotten a little better and soundstage has improved as well, location of sounds has become more apparent.
The Downside:
No real flaws with the sound to be mentioned IMHO. However, fit has been somewhat finicky for me, it takes a little adjustment before a good seal is found. As with all IEMs you know you've got it when the bass becomes more apparent. Isolation is also not as good as the E500s (I was using the triple flanged tips which I cut and made into biflange). In hopes of remedying these issues I have ordered some Comply tips. The cord is definitely an annoying issue for me. The J-shaped design is just plain stupid IMHO and the thinness of the cord itself allows it to easily tangle.
P.S.
Does anyone know who I could contact about getting these recabled?
-sid
The Upside:
The Downside:
P.S.
-sid
