SONY IER-Z1R
Aug 27, 2023 at 1:01 AM Post #14,476 of 15,290
personally, i still prefer the Radius Deep Mount over the Final E
I'll finally get back to Japan in December, e earphone have a case of tips to demo, I'll give those a go
Aug 27, 2023 at 2:00 AM Post #14,478 of 15,290
Jealous. E earphones is the best place to visit...haha
Those are not new earpieces though^^ they are all used and some of them quite old. When i tested the COMPLY T-200 and Ts-200, they felt like years old :D they get the job done but its a singificant difference to a new pair.
In the store i was "Yeah, they are okay" but when i bought them the new pair felt much better and also sounded much better.
So its cool that you can try the tips, but they are not new sadly.
Aug 27, 2023 at 2:12 AM Post #14,479 of 15,290
Yeah they aren't new. I guess for foam it's hard but the silicone tips are good for a listen. But it's fun to also try all the different earphones... I easily spend a day there listening to all three iems and try out daps as well
Aug 27, 2023 at 3:12 AM Post #14,480 of 15,290
Last time I was there 5 years ago I only had a ZX300 and XBA-Z5 (with Sprial Dots) - as you can see from my signature my audio realm has expanded so I am going to make maximum use of the opportunity to try different gear and acquire accessories.
Aug 28, 2023 at 8:55 PM Post #14,481 of 15,290
I just can't stress how much I love these IEM's, after switching to HD800S for a few months (paired with a decent tube amp) I still come back to the Z1R for the intimacy and the BASS that hits just the right spot. I really don't know if there's anything that's significantly better than the Z1R's, anything else at most is a side grade not an upgrade.
Aug 29, 2023 at 2:15 AM Post #14,482 of 15,290
Pncezpi kear the itopia, it will kill the 800S for you
Aug 29, 2023 at 11:08 AM Post #14,484 of 15,290
i have a moondrop blessings 2 dusk and like it. Have tried Variations but for some reason liked the dusk better for forward vocals i guess. What should I consider around a $1K usd range as an upgrade?
Wrong forum?
Aug 29, 2023 at 11:12 AM Post #14,485 of 15,290
If you manage to get an IER-Z1R for 1k (which is possible used), that is most likely an insane upgrade.
But if you're talking new, that is complicated. Not the IER-Z1R :D
Aug 29, 2023 at 11:59 AM Post #14,487 of 15,290
Blessing 2 dusk upgrade with similar tonality and vocals at the best with $1000 price, get Monarch MkIII or MKII (monarch mkII have bad bass quality as TOTL), better get mkIII.
But yeah this is Z1R thread. I prefer Z1R than Monarch 😎
Aug 29, 2023 at 12:11 PM Post #14,488 of 15,290
Variations already makes singers sound like Alvin and the Chipmunks or Hatsune Miku depending on their reproductive system so I’d be terrified at something having even more forward vocals.
Aug 31, 2023 at 2:29 AM Post #14,489 of 15,290
My Z1R has been revived after some careful repair works. I guess this will be the end of cable rolling for me and buying all these cheap cables from the PRC. I will from here on out stick with my MUC-M12SB1.
Ready to listen to some good tunes and contribute to this forum again!:L3000:
Sep 1, 2023 at 5:23 AM Post #14,490 of 15,290
One question to the owners here: The balanced cable is new, never, used, kept in a cool room with no drastic temperature changes.
Why does the cable look like this after a while?
  • Pa1n
