Python002
- Aug 5, 2010
I’m leaning to get those customs as well. I have to find a new place to do my molds. They went from $50 to $100 .
Customs form a great seal with your ears no doubt, but in my experience would alter the sound quite a lot as the path directing sound into the ear canal is tweaked and the invariably longer path means diminished trebles, which is where a large part of Z1R's magic lies.
I remember with my 530s using the foam tips for years. Then decided to try standard silicon and realised how much the foam muffled the sound. One reason why I'm never convinced about customs - unless the IEM is designed to be custom, too much of a potential downside.good point. I remember years ago going that route with some shure 530’s I think they were. Didn’t sound the same with the custom ear tips.
How did you fish it out? I’m afraid to mess with mine. I pushed them in being careless. They sound the same so I have been afraid to mess with themDoes anyone have a picture with out the foam in the nozzles? There’s been a few times I’ve cleaned and tried to fix the foam inside when it has went too inside and I’ve felt something in there when I fished it out with an iem cleaning tool end. I’m afraid that I probably felt the treble driver. They sound fine to me
It was using the little loop end from those iem cleaning tools with an end brush. I’m just being paranoid I don’t think it was long enough to reach the driver anyways.How did you fish it out? I’m afraid to mess with mine. I pushed them in being careless. They sound the same so I have been afraid to mess with them
The foam is supposed to be a bit inside? I wasn’t trying to remove it, just bring back up how it was. Was also cleaning some wax inside.The foam is supposed to be glued in place. @Whitigir experimented with removing it and replacing it with something with different density
Mine sits a little belowe the lip of the nozzleThe foam is supposed to be a bit inside? I wasn’t trying to remove it, just bring back up how it was. Was also cleaning some wax inside.
Ahhh ok I left them like that now and I was able to clean the nozzle foam with a wet wipe. Wonder how long it will last, doesn’t seem like you can get replacement foams.Mine sits a little belowe the lip of the nozzle
