Full fiio silver. Lovely fit. These are LC-3.5D
Cool thanks, I'l have a look for those TC50 tips among a few others folks have mentioned.Congratulations~
Enjoy your z1r...you will be kept on surprise whenever you feed it with a more powerful source
You can search Sony EP-TC50 Triple Comfort Replacement Eartips ...should be similar or same hybrid ear tip with the z1r
Do you ever wash your foamies? Just damp cloth? No degradation to them if so?
Can anyone recommend a upgaded cable for the Z1R's? I'm looking for something that will give them slightly more sparkle. 4.4 balanced.
Struggling to find something that looks swish and is available in the UK. I really wanted the Dunu Blanche but can't find one for love nor money.
Warm water with a drop of dish washing liquid, had mine since 2017 (triple comfort tips) afaik, they are not regular foam, they are made from aerated silicone and retains their form better.Do you ever wash your foamies? Just damp cloth? No degradation to them if so?
Both sides are the same on mine, but that happened when the cable broke on one side on my first pair. Have you tried reseating the cable?Hi all, is it just me or the grey mmcx connector go in a bit further than the red side? Does anyone's unit look the same with the stock cable?
Both sides are as tight as each other and it does not affect the sound, but my OCD is getting the better of me![]()
