I have both, and I think :
Wm1zM2 >>> Dx320 + Amp 11.2s
DX 320 + Amp 13 >>>>>>> Wm1zM2
I'm curious about RS8 also
I have to use the L to even get a seal and previous LL on the Final E tips and then they still go super deep. I have huge lug holes, my custom JH13 shells are about same size or slightly larger that the Z1R houseSadly Z1R doesn't even fit into my ear canals with Coreir size S. They just hang there, which is not a good thing for Z1R.
Yeah, my Amp11.2 pretty much stayed in the box after Amp 14 arrived. I lean towards musicality vs analytIcal sound.I have both, and I think :
Just bought the official 4.4mm stock cable, and then bought the Brise Audio BSEP cable, should make up mind for BSEP sooner, I have already bought 4 upgrade cables for Z1R. Lesson learned: always go to the best choice, you will end up there anyway, so just save your $$ to buy those less than best choices.
I have to wait for almost 3 months at least for it to ship since Brise Audio is backlogged. Will share if the cable worth it or not.Just looked up this cable and man it’s nice but I can’t bring myself to spend that much on it when the stock ones work very well for me.
That's some wait for a cable. Looking forward to hear more about it from you then.I have to wait for almost 3 months at least for it to ship since Brise Audio is backlogged. Will share if the cable worth it or not.
I do, but for me the regular azla sedna light short (white translucent umbrella with blue stem right?) Still cant make perfect seal like maybe azla sedna crystal (same shape, different material). You can try that one if you like, but personally I'm settled with pentaconn coreirHello all, just joined the party! Has anyone ever tried the AZLA SednaEarfitLight Short tips with the Z1R?
I think they're incredible tips that make the bass kick like a mule, and fortify the upper midrange of any set they're on. I'm curious if anyone has tried those, and has a better recommendation.
Z5 is the only iem ever I could not get a good fit withWish I could buy Upgrade from XBA Z5 to IER Z1R but wallet and fit are problematic for me
On my Z5 i use my the custom art tipa and they feel like a globeZ5 is the only iem ever I could not get a good fit with
