smokecrack
- Jul 2, 2012
Yea so I've tried the following tips since getting my M9 and I figured I'd share my thoughts on each of them. If you just want to know which I think is the best skip to the bottom.
edit, see below for my thoughts on the CP100
- Sony Hybrids (Size SS)
- Very comfortable and high quality. If these were my only option I'd be fine with this option. They are the softest silicone tips of the bunch with the exception of the triple comforts. A little wider than similar tips like the Final Audio so they seal a little better. Let's call this the "neutral tip" on which I'll compare the rest to. Good bass slam on these, wide soundstage, crisp highs. Pain in the ass to buy extra tips (ebay or encompass in the USA). You may need to get tips meant for the Sony IER-Z1R but they'll be the same aside from maybe the color.
- Sony Triple Comforts (Size SS)
- The most comfortable tips I've tried. The material is a special "silicone foam" which I haven't seen before. If I am going to wear my M9s for longer than 8 hours I think I'd probably go with these. The sound becomes a bit warmer with these but you lose some of the crisp high end. This change in tone makes them even less fatiguing (not that they are fatiguing to begin with; I'm talking about long stretches of wearing IEMs). So if you just want a relaxing listen or are taking a 12 hour flight these are the best choice. Pain in the ass to buy these too, but easier than Sony Hybrids in my size (ebay or encompass in the USA). You may need to get tips meant for the Sony IER-Z1R but they'll be the same aside from maybe the color. Their longevity is questionable.
- Final Audio E Type Tips (Size SS)
- These are interesting. They are excellent quality and fit the M9's even better than the stock tips! They kind of *click* in. The silicone is a little more firm than the Sony Hybrids but they are still comfortable. If you have really tiny ear holes I'd give these a try. I personally prefer the Sony Hybrids to these but it's a toss up and depends on your ear shape. Also these come with the nicest ear-tip box I've seen, so even if you hate the tips you still get something nice
Sound-wise these are very similar to the Sony Hybrids. Easy to get these on Amazon.
- Spinfit CP145 (Size S)
- My least favorite of the group. Maybe because the CP145 doesn't come in size SS which I clearly prefer. They are very "wiggly" and I can see you liking them if you have a longer ear canal. They are comfortable for sure but I just didn't like their longer profile. Sound-wise they are more muffled than the others but still have decent bass. They are a bit more boomy than the others so if you want to maximize the bass impact I'd try these. Easy to buy these on Amazon.
- Spinfit CP100 (Size SS/XS)
- Ordered but have not tried them yet. edit, see below.
- AZLA SednaEarfit XELASTEC 2 Pairs (Size SS)
- These are second most comfortable after the Sony Triple Comforts. Their special material softens and forms to your ear shape when in contact with your warm ear. Because of that they provide the most custom IEM-like fit. You sort of just forget you are wearing them after a while. The sound is what really sells them though. Because of the nice seal they form the sound is noticeably changed. They are definitely less warm. Mids come a little forward, the bass has more impact, and treble is boosted too. I tend to lower the volume when wearing these tips vs the others because I get the same clarity at lower volumes. I haven't wore these for long periods of time so I can't attest to their comfort for hours and hours, but I will say these are probably the least relaxing sound for long periods and can see you getting a little hearing fatigue unless you drop the volume. These also come with a nice case, but nowhere near as nice as Final Audio's. I think the biggest downside of these is the material. It's a tacky silicone/plastic material that really attracts whatever lint or wax that's laying around in your ear. If you clean your ears regularly you should be okay but even so be prepared to wipe them off once in a while with an alcohol pad or a damp cloth. The benefit of the tacky material means they are the best at staying in your ears when moving around or chewing. Oh and if you are after noise isolation these were easily the best. Easy to buy these on Amazon.
