WilliamBlake
Does anyone know if that sort of foam, I don't what it is, inside the nozzle is removable?
this foam is actually a filter. It is glued inside and I wouldn't risk taking it off because sony doesn't make it available for saleDoes anyone know if that sort of foam, I don't what it is, inside the nozzle is removable?
Thanks man, I was asking beacause it seems a bit recessed inside, but don't want to touch it since the sound is ok, I'd probably do some damagethis foam is actually a filter. It is glued inside and I wouldn't risk taking it off because sony doesn't make it available for sale
Thanks, I took a photo yesterday and it's like thisI post on Z1R thread, but should be the same with all sonys, get gentle tweezer, you can pull the foam it will stretch with bottom part will be still connected to the nozzle, pull it gently until the foam is above nozzle level, then just release it and it will form back to original state, or you can use needle also to "uplift" the foam.
Same method if you want to clean the foam from earwax debris.
It looks like the previous owner has already removed the filters and tried to put them back in place.Thanks, I took a photo yesterday and it's like this
are them too recessed?It looks like the previous owner has already removed the filters and tried to put them back in place.
I use the Sony EP NI1000 M. They are my favorites, they don't have the problem of vacuum, they leave the m9 with an excellent soundstage, they are durable and sound like the silicone ones. Unfortunately they are very expensive, but worth it. I got good results with spinfit cp100, bgvp 008 and EPRO horn tips.are them too recessed?
edit: managed to pull them back with a toothpick, they're ok now
Still trying to figure out which are the best tips with these iems!
The epn... are very different from the stock ones(triple comfort)?I use the Sony EP NI1000 M. They are my favorites, they don't have the problem of vacuum, they leave the m9 with an excellent soundstage, they are durable and sound like the silicone ones. Unfortunately they are very expensive, but worth it. I got good results with spinfit cp100, bgvp 008 and EPRO horn tips.
Just be careful with the insertion technique so you don't cause a vacuum, which can definitely kill the low frequencies.
They are closed, thats pretty normal and also heavily influences the sound.The epn... are very different from the stock ones(triple comfort)?
I tried so far final e, azla sedna, spinfit cp100 i guess, they came with a campfire set, epro. But I got a bit that vacuum feeling especially in my left ear (I think I've very different ear canal), with azla the more, with final and spinfit less, but maybe is the material the problem.
I've looked for these tips, but found them only at accessory jack, nobody in EU sells these?They are closed, thats pretty normal and also heavily influences the sound.
With closer IEM there is almost no way around foam tips like the EP-NI1000, AIRISM, Comply or others.
It also increases the isolation by factor 10 and reduces the reverb of your own body noises in you ear drastically.
Because I wrote nonsenseI've looked for these tips, but found them only at accessory jack, nobody in EU sells these?
I'm a bit skeptical about this tips, seems to degrade really quickly, I'd prefer to spend on the sony even if they're more expensive https://www.accessoryjack.com/colle...-for-wf-1000xm4-true-wireless-earphone-1-pairBecause I wrote nonsense
The EP-NI1000 are sold out right now as it seems, but the AIR1 are just as good. They don't last as long, but isolate better
Mine last around 1-2 weeks which is okay for memory foam, especially the way how heavily I use themI'm a bit skeptical about this tips, seems to degrade really quickly, I'd prefer to spend on the sony even if they're more expensive https://www.accessoryjack.com/colle...-for-wf-1000xm4-true-wireless-earphone-1-pair
It seems to me that you still haven't heard the full potential of the IER M9. This suction effect in the ear greatly affects the final sound of the in ear. That's why the insertion technique is so important. The eartip has to seal the ear canal, but not to the point of having this effect. EPNI1000 does not cause this vacuum effect, seals better and has the sound of silicone eartips. They are considerably more durable than conventional foam eartips, but they are also more expensive.The epn... are very different from the stock ones(triple comfort)?
