osiris1
- Jun 4, 2012
you're welcome. spread the loveYe
Yeah i think is just a matter of color preference.
P.s.: have to thank you cause i bought the radius tips after reading your postings
i just bought the deep mount and using it right now. i have to say i really like them.I have to agree, I did not use the M9 too much and was on the brink of selling them, after trying all the tips I have, including the Radius Deep Mount, I decided to keep them, using the Deep Mount tips
The seal is great with those tips, they seem bespoke for sony iemsi just bought the deep mount and using it right now. i have to say i really like them.
good fit with size M on my ier z1r. they feel more fixed in comparison to final audio type e in size M.
I'm going to buy a set to try.The seal is great with those tips, they seem bespoke for sony iems
i highly recommend that.I'm going to buy a set to try.
I bought the vivid together with the radius, but I didn't even tried them. Actually I don't know why I get them since with the sedna my experience is not too goodI tried the black Radius deep mounts & yes they are good but these are better to my ears, wider sound stage with great bass & pleasant treble. Sednaearfit vivid edition.
I tried the black ones with every iems i have but nothing, whatever, we all have different earsI don't like most of the sednaearfits.
The only ones I like are the standard black & the vivid.
I tested the Silver Litz Fiio with my M9's that came with my Fiio FD7's. Connected fine but obviously not as visually designed to blend perfectly as the supplied cable. I think the supplied cable is great anyway.Ok, even before i have them i am curious about cables. Are the Sony's a true MMCX ? I have several of these in Dunu Noble and Blanche with quick connectors which is so helpful with different sources.
Secondly tip suggestions please.
Tia
Yup. The IER-M9 connection is a true MMCX, however, not every cable is perfect in it just because of the recess. Sony and third-party cables with their own plugs for the M9/M7/Z1R adapt perfectly to the in-ear. I advise you to buy the CEMA model PS cable. I have and I really liked the visual and sound resultOk, even before i have them i am curious about cables. Are the Sony's a true MMCX ? I have several of these in Dunu Noble and Blanche with quick connectors which is so helpful with different sources.
Tia
for my little experience with these, the stock cable is very nice and good, but I want to try another one cause sometimes I find the earhooks a bit uncomfortable, but lookin for something that fits the mmcx connectors like the original, not easy, cema is an option, I see plussound have sony connectors as an option, but the brand is really pricey.Ok, even before i have them i am curious about cables. Are the Sony's a true MMCX ? I have several of these in Dunu Noble and Blanche with quick connectors which is so helpful with different sources.
Tia
