MattTCG
- Jan 22, 2012
I was looking for someone who has tried SW with the hd700. Is it as revolutionary with the hd700 as it is with the hd800?
The degree of "improvement" should scale inversely with how "neutral" the headphones sound signature is to begin with.I was looking for someone who has tried SW with the hd700. Is it as revolutionary with the hd700 as it is with the hd800?
The VST works fine with Foobar (load it with its VST Wrapper). The new systemwide version is extremely unstable and therefore useless at this point. I've tested it for about a day and gave up. I don't even know how it was implemented but it doesn't seem to be an APO. You can turn the VST into a systemwide plugin using virtual soundcards for routing and a standalone VST host like VSTHost or SaviHost. It's stable.
As far as I know they have not released a Windows version yet. The Mac version which I have been running for about a month works great. It has a couple small issues like having to reset it's output device following system sleep or powering off the output device but they are working on fixing it. The fact that it handles both headphones and speakers all in one simple tray app is definitely worth using in my opinion it really improves the sound to all calibrated devices I have used it on. t has impressed me so much I am packaging up all my headphones and shipping them to latvia for calibration next week. I mean if I can get my T1 for example to sound like my LCD-X my neck will really thank me for that
They have, I got a notification on the 23rd along with a 5 day trial key. I'm not questioning its usefulness as it does a marvelous job compared to a few others I tried (by far my favorite).
The HD800 does indeed have better bass than the HD700. With Sonarworks, its bass is exceptional for most genres.
I've tried a number of mods to get the best bass out of HD700, and so far my favorites are the "Blendtec®" mod and the "invisible cable" mod. For the first one, take the HD700, and put it in a Blendtec® (you can see this mod applied to an iPad here, and if you don't have a Blendtec®, a Vitamix is an acceptable alternative). Then, puree the HD700 until it is in pieces smaller than 1cm. This bass sounds better than any other configuration I've tried.
For the more reversible "invisible cable" mod, unplug your cable from your amp and from the HD700. Ask a friend or spouse to hide it somewhere in your home. Then, turn on your amp and listen as usual with an invisible cable.
yeah even the mac version was hard to get going. the breakthrough was realizing it requires purchased headphone and speaker plugin licenses. In other words you cannot demo systemwide unless you already own their headphone and speaker plugins, the plugin demo licenses do not work with it. once you buy the plugin licenses it works fine. basically you are demoing systemwide, not the plugins. if you want to demo the plugins alone then you would need a good VST player. but i would argue the value of this is in the systemwide app in that it doesnt require being a audio guru to setup (once you have the licenses). it just runs in the tray across all audio of the computer.
