bosiemoncrieff
You need the X86 version.
of what exactly? Sonarworks? I clicked the mac download. on the webpage. the activation code is just a string of digits and hyphens, and is what gave me the error message.
-- copied from LCD-X thread because it should also be useful here --
Everything is working fine for me regarding systemwide and all but it wasn't without considerable troubles to get the licenses activated etc. Ultimately you need to purchase real full licenses for the plugins first since the systemwide demo doesn't support plugin 21 day demo licenses. once you get a real plugins license key then you need to activate those via something like JRiver or AudioHijack or whatever VST plugin loader by loading the plugin and waiting a minute or so until it actually starts to render from being an empty panel (maybe click around a bit and drag the window a bit until it finally displays) and enter the real license code to activate the plugins. Then once you got real plugin license activated do a reboot and go back to systemwide and it should show green checkboxes for those license. Then you need to enter a new different systemwide demo 5 day license which I was given myself via a support email to Sonarworks. The advertised 5 day license on their website or wherever doesn't work. Once you got a fixed license then finally it should all just work.
The LCD-X calibration file is in the plugin folder '~/Sonarworks Profiles' under your home folder on a mac. This folder should have a bunch of .swhp (SonarWorks Headphone Profile) files including the LCD-X. It should open the correct folder when you go to select a profile in the upper right drop down. If you don't see the X in the list of profiles it means you do not have the latest plugin updates. In that case go to their website and download the latest plugins. There is no 'flat' calibration profile included with the plugin so until you set something you get nothing.
I try to load the VST plugin into Fidelify and it can't register it.
Guess I'll just have to wait for Systemwide for Windows to try this.
Either for mixing purposes or just plain music listening, at some point you probably wished for a system-wide solution to listen to your music through our Reference 3 plug-in. While we’re still working on a system-wide solution ourselves, here’s a quick guide to a solution for Windows that works for free right now! For this you will need to download two applications that serve the purpose of hosting our plug-in and then routing it to your system's sound output.
Step 1:
Download and install the latest build VB-audio cable from here: http://vb-audio.pagesperso-orange.fr/Cable/
Step 2:
Once installed, restart your computer and go to your Sound preferences in Windows. Click on the Playback tab and select VB-Audio’s CABLE input as your playback device.
Step 3:
Now download and launch Pedalboard 2 (http://www.niallmoody.com/apps/pedalboard2).
Step 4:
On the toolbard press Options, then on Audio Settings.
Now in the Audio Settings window Select “Direct Sound” as your audio device type. Select CABLE Output (VB-Audio cable) as your input and built-in output or your soundcard/interface as your output.
Step 5:
Now double-click on the open space in PedalBoard2 to add a audio plug-in and select the Sonarworks Reference 3 plug-in. If it doesn’t show up, go again to Options, Plug-in List and then scan for new plug-ins.
Step 6:
The Sonarworks Reference 3 plug-in will show up in the middle and you will need to connect the corresponding inputs and outputs, like shown in the picture.
Step 7:
If you wish to open up the plug-in interface and change your calibration profile or other setting, just press on the letter “e” on the selected module.
That’s it, you’re good to go!
Here's a guide from a post on page 3 on this thread:
Okay, I got it to work with foobar2000. Here's what you need to do.
Download and install the free trial of Sonarworks Reference 3 Headphone. (Or purchase it.)
Download and install the VST adapter in foobar2000.
Go to Components, VST plugins and add the Sonarworks plugin.
Go to Playback, DSP Manager and activate the Sonarworks plugin. Then click Configure Selected.
Finally got Hijack and Sonarworks working. Pedalboard is a worthless piece of schiit. Pops and sputters all over your sound. Can't overstate how crippled and terrible a solution it is. Stock HD800 is preferable.
