Currently Systemwide is for existing clients only. Hence the e-mail was sent to them. I'd wait a week or two before we release the Win version and then jump on it.
Existing client here, no email to me.
Copied from this thread....
Okay, I got it to work with foobar2000. Here's what you need to do.
Download and install the free trial of Sonarworks Reference 3 Headphone. (Or purchase it.)
Download and install this VST adapter in foobar2000.
Go to Components, VST plugins and add the Sonarworks plugin.
Go to Playback, DSP Manager and activate the Sonarworks plugin. Then click Configure Selected.
So I want to try Sonarworks.
I downloaded it & after what felt like 10 installed it finished, but what now?
How do I use it with foobar, there is no instruction or read me file? The installation installed in several different folders, what am I supposed to pick to use in foobar?
When a new software is being released, there's often delays and hiccups.
I wouldn't sweat over it.
The deals also come and go.
Does AudioHijack require sound flower as pedalboard did? I used PB but it made numerous cracks and pops. Also, how do you call up the sonar works plugin in AH3?
When I try dragging & dropping the Reference.dll
I get this message:
Could not load component "Reference3_x64.dll": Unsupported format or corrupted file
Do i have to somehow use the trial key code or open some separate Sonarworks program to get the .dll file to be supported?
The only deviation from the other instructions I did was download the VST plugin from http://www.yohng.com/software/foobarvst.html
Instead from https://hydrogenaud.io/index.php/topic,84947.0.html as clicking on the link to download it doesn't nothing.
