bigshot
It does seem to be more than just a straight-through plug-to-socket from the pictures
No. It *IS* just a straight through plug to socket. If you've ever replaced your own plug on a set of headphone or turntable, you got connectors with three pins on them exactly like this at Radio Shack.
Not disagreeing, but if you took apart a capacitor, not knowing anything about what it was or how one worked, what would you make of what you found inside? What I am saying is: Just because we don't know what exactly is inside it, doesn't mean it doesn't do anything significant.
We do know exactly what is inside it. It is a female 1/4 inch plug jack on one end, and a male 1/4 in plug jack on the other, connected by three wires for left, right and ground. Check your headphones and see if the housing around the jack on the end of them unscrews. If so, you will see three wires connected to pins on the back of the plug just like this. A headphone jack is a connector. It doesn't affect the sound. All it does is allow you to put the plug from your headphones in one end and patch the signal directly into the plug on your amp.
All this consists of is an additional two and a half inches of wire.
I feel like I'm in Alice in Wonderland here!
