Hi there,
I'm a pretty noob head-fier and just started getting into the world of audio and just wondering out of these 3 headphones, which ones should I get?:
- Monster Inspiration (also considered the Purities)
- SOL Republic Tracks HD
- Beats Studio HD
I know i've read everywhere that these headphones might be a full of crap/ overpriced headphones and that there are better ones such as Shures or Klipsch etc. but i really just want good looking headphones, with nice and clear lows, mids and high with a punchy bass, but not too overpowering. Since I'm quite limited by choice as well in NZ, these are the ones that I'm interested in. Any advice?
Here are my two cents worth after using the Monster Inspiration for about a month.. I initially wanted the v moda m100s but i dont regret getting the monsters. I wanted a really fun sounding pair of cans and this is really awesome for modern genres of music ( rnb, hip-hop,pop,rock,dub step, i dont listen to jazetc..) PLUS i think it looks fantabulous !!! I can post picts of them if you want
[size=small]
Source. Sansa Clip Plus[/size]
[size=small]
Amp. Fiio e11[/size][size=small][/size]
[size=small]
Base of comparison. SENNHEISER HD 25-1-II (Adidas)[/size][size=small][/size]
[size=small][/size]
[size=small]
Sound Signature (NOISE CANCELLING OFF with amp).[/size][size=small][/size]
[size=small]
Great bass and good treble with a better sound stage than the hd 25 and good separation of instruments. The mids are not as bad as the other beats models like the solos and hds and even the pros but not as forward as the hd 25s. Overall this is geared towards modern music... Pop, rnb hip-hop, drum and bass, rock, dubstep. etc...[/size][size=small][/size]
[size=small]
Since i have the very balanced hd 25s i wanted something that was fun sounding with good base emphasis and this do not disappoint. With an amp the headphones vibrate and its like a sub woofer next to your ear all without sounding too muddy or drowning out the mids too much. The highs are very well defined. Even though you don't need an amp to drive these cans, i belief its really awesome with an amp. In fact most cans are really much better with a good amp for those who are serious about their music.[/size][size=small][/size]
[size=small][/size]
[size=small]
Noise Cancelling on.[/size][size=small][/size]
[size=small]
Noise cancelling is mediocre at best. Compared with Bose. But it does work and it does cancel out some ambient noise. The over-ear ear cups also provides good passive isolation so overall in total its quite effective at blocking out ambient noise just don't expect all sound to disappear though. The noise cancelling feature also acts as a bass and volume booster. But the best thing with these cans are that you have the choice to switch it on and off and still use them without batteries unlike the bose and the studios.[/size][size=small][/size]
[size=small][/size]
[size=small]
Sound Leakage and sound isolation.[/size][size=small][/size]
[size=small]
As mentioned before sound isolation is above average. With noise cancellation switched on its slightly better then the hd 25s which are known for effective passive noise cancellation. Sound leakage is another matter though as its worse than the hd 25s. It does leak some sound so taking it to the library and blasting the music is not such a good idea.[/size][size=small][/size]
[size=small][/size]
[size=small]
Comfort & Built.[/size][size=small][/size]
[size=small]
This depends on the size of your ears. Mine just fits. The ear pad cushions are really soft and feels great. Clamping force of these headphones depending on the size of your head can be fairly tight to moderately tight.But nowhere as bad as the mixrs and much more comfortable than the solos and hds. Although my ears do not rest on the speaker grill the outer ear does come in contact with the cushions and can be uncomfortable after a couple of hours. You have to get the right fit with these things. I wish they were a little bigger. Another thing though are these cans seem well built to me but you do feel its weight on your head. They aren't the lightest pair.[/size][size=small][/size]
[size=small][/size]
[size=small]
Conclusion.[/size][size=small][/size]
[size=small]
I bought mine "used like new" from Amazon warehouse for about 250 and for that price its worth it.[/size][size=small][/size]
[size=small][/size]
[size=small]
Pros.[/size][size=small][/size]
[size=small]
Sound signature[/size][size=small][/size]
[size=small]
Base[/size][size=small][/size]
[size=small]
Good Looking[/size][size=small][/size]
[size=small]
Great accessories[/size][size=small][/size]
[size=small]
Changeable Headbands[/size][size=small][/size]
[size=small]
Foldable to a compact size[/size][size=small][/size]
[size=small][/size]
[size=small]
Cons.[/size][size=small][/size]
[size=small]
Heavy[/size][size=small][/size]
[size=small]
Might be uncomfortable for those with big heads and big ear lobes.[/size][size=small]
Its comfy if you can find the right fit or have small ear lobes..[/size]
[size=small]
Hope it helps[/size]
[size=small]
Cheers[/size]
