So, the Objective2 headphone amp - designed entirely around the measurements? (PLEASE READ RULES BEFORE POSTING)
post-7680605
Post #256 of 1,042
Head Injury
kwkarth, if you're not going to provide any objective concerns, I don't think this is the thread for you.
Anonanimal, very handy table. Could you add LCD-2 rev.2 to the list for me? Audeze increased impedance to 60 ohms. Thanks
(I suppose I could just use the K701 and rev.1 as approximations)
post-7680618
Post #257 of 1,042
Anonanimal
Sure.  I've upped the dB requirement to 115 for some additional headroom for quieter recordings.  In practice I've found this to be enough, but again YMMV.
I'd attach the .xls file instead of posting screenshots but I seem to have been denied that ability.  Sorry!
post-7680620
Post #258 of 1,042
kwkarth
Electronics guys... we have our plusses and minuses. With advent of digital everything, we're being phased out
Where is your data showing that the amp does not, by spec, have enough output to properly drive the quoted headphones?
Actual power specs:
6.25 volts RMS on AC power at < 1% THD into 150 ohms
4.5 volts RMS on DC power at < 1% THD into 150 ohms
Compare to this calculations chart using actual headphone specifications.  This is using a Gamma2 as the reference DAC.  YMMV but this should give you an idea.
Nice chart!  To answer your question, one word...  headroom.
post-7680637
Post #259 of 1,042
limpidglitch
Sandnes
Sandnes
Why not uploading the file to mediafire, Google Docs or similar, and post a link?
post-7680644
Post #260 of 1,042
Anonanimal
I can do that if there's interest.  It's a series of pretty simple calculations but I've got them packed in a table for quick reference.
post-7680658
Post #261 of 1,042
kwkarth
I think it's potentially very useful!
post-7680680
Post #262 of 1,042
digger945
Indeed, Google Docs integrates seemlessly for me and works great with Excel, whether uploading or downloading to or from Google Docs.
post-7680703
Post #263 of 1,042
nikongod
DIY-ku
Nice chart!
Your numbers for Beyer and Sennhesier are off. These companies declare efficiency in "db@1v", except for the HD600 whose efficiency is declared in db/mw.
Im not sure about the AKG K701. it "looks and feels" like the declared efficiency (also given by AKG in db@1vrms) has been converted but Id double check by setting the "target spl" to whatever AKG says the K702 has@1v, and seeing what you get for voltage required :)
The gain you give in the far right column assumes that you have a 1v input signal. If you have quiet music you may only have a 0.25v signal or maybe even less with that same DAC. To achieve 115db with Hd800, and a quiet recording it could require boatloads of gain... If you want the amp to play LOUD there is no way around including the gain switch.
post-7680726
Post #264 of 1,042
Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
Can anyone provide the formula that converts from sensitivity in V to mW?
post-7680743
Post #265 of 1,042
The Monkey
Monkey See, Monkey DAC
A really sick dud
I'm a bit confused why there's a de facto assumption that this is designed to be a portable amp. From what I can glean from the designer's comments, the amp in its initial iteration is small, and therefore portable, but the designer also indicates that the amp also is suitable as a desktop amp (with bigger enclosure if wanted and other options). Regardless of whether the amp is used as a desktop or portable, it does not appear that there are any substantive differences in configuration. In other words, the amp designer appears to suggest that this amp is equally suited to desktop duties as it is to portable. So until someone offers a compelling reason to the contrary, I think limiting assumptions about the types of sources used to portables is inappropriate. Did the designer not use the Benchmark's amp as a comparator?
post-7680761
Post #266 of 1,042
kwkarth
Watts (W) or milliwatts (W/1000) are the product of Voltage (V) and Current (I) and  R=V(2)/I .  therefore...
A sensitivity of 105dB / V is what is published for the AKG K702.  It has a published impedance of 62 ohms, so, our knowns are Voltage and resistance.  Since W=V(2)/R, then 1/62=0.01613, or roughly 16mW required for 105dB output from the AKG K702.
post-7680784
Post #267 of 1,042
fishski13
Member of the Trade: SolderWorksAudio
I'm a bit confused why there's a de facto assumption that this is designed to be a portable amp. From what I can glean from the designer's comments, the amp in its initial iteration is small, and therefore portable, but the designer also indicates that the amp also is suitable as a desktop amp (with bigger enclosure if wanted and other options). Regardless of whether the amp is used as a desktop or portable, it does not appear that there are any substantive differences in configuration. In other words, the amp designer appears to suggest that this amp is equally to desktop duties as it is to portable. So until someone offers a compelling reason to the contrary, I think limiting assumptions about the types of sources used to portables is inappropriate. Did the designer not use the Benchmark's amp as a comparator?
the performance goal posts keep moving to suit a particular line of argument.
i generally recommend keeping the gain as reasonably low as possible for improved noise and giving you more play/adjustment with the volume.  also, a lower gain will give you better distortion numbers with increased negative feedback.  while the above table re: HP power requirements is handy, i would caution and reiterate that the source recording may not output enough V to achieve modest volumes, much less silly 115dB, under what i consider to be 'real world'/common playback situations.  choose your source and HPs carefully.
post-7680792
Post #268 of 1,042
Armaegis
That part I know. I was wondering about the conversion from 1db/V to 1db/mW, which I'm pretty sure has a log or two in there. I could probably do it, but I'm a little too sleep deprived to crunch numbers right now.
... doubling power... roughly 6dB... 2^x... equals P... zzzzzz
post-7680822
Post #270 of 1,042
bcg27
Someone should double check this to make sure I didn't make a mistake but:
Sensitivity @1mW=sensitivity @1V - 10*log(P(1V in mW))
if you want to substitute in the formula to get power from 1 volt you get
Sensitivity @1mW=sensitivity @1V - 10*log(1/R*1000) = sensitivity @1V - (10*log(1/R)+30)
logs are base 10 logarithm
