1. I have the 800S and have no problem with the A16 volume. I normally run at volume level 55. Try it with one of the factory presets and see if the volume is still lacking.Hi all,
I am not sure where to post this but hopefully this is the best place?
1. I find it very quiet unless you have the volume almost maxxed out (i.e. 90-95), but then it clips during lively scenes and automatically reduces volume (see below). Is it just me, or should I look into using a separate headphone amp? If the latter, are the RCA outputs best?
5. Has anyone tried the PRIRs from 3D Sound Shop? Is there a huge improvement over the supplied two?
Thanks in advance of your help.
Tim
5. I have the Genelec 3DSoundShop PRIR. These PRIRs are recorded at 6' distance with little room sound. I sit 10' from my TV and found that the Surrey factory room gave a better illusion of space to my ears. I'm currently using my own PRIR recorded at a 10' distance.
