What I know for sure is that under firmware 2.13, my Realiser A16 unit detected and decoded Auro-3D files (embedded in FLAC). I can’t remember exactly how it was with firmware 2.15. However, I tend to think it was the same with 2.13.That is apparently kind of expected with Auro 3D - it isn't detected automatically under most circumstances, as far as I can tell. Check if "native" Auro 3d is engaged if you enable the Auromatic upmixer. This is how Auro works with all AV Processors that I've had access to so far. On the player side, you have to make sure that the stream is output bit-perfect, with no volume adjustment or DSP shenanigans. FLAC cannot be transferred over HDMI as FLAC, it has to be decoded to PCM.
At 2L.no site, there’re instructions on playing Auro-3D files (embedded in FLAC).
“Play via Blu-ray player: Save the downloaded file on your USB stick, DVD-R, or BD-R. Insert those into your Blu-ray player and play the file the same way as you would play a Blu-ray disc. AURO-3D can be reproduced from your AURO-3D AVR when connected to a Blu-ray player via HDMI.”
https://shop.2l.no/collections/auro...eqqwNtgIWpSo6OcZ0JvV_0J99-PxUdRtVVsMRPAC7f0Mp
In my previous post, I wrote “I sent (bitstream)…” taking into account the instructions posted at 2L site (“and play the file the same way as you would play a Blu-ray disc”).
It’s certain that starting from the Auro-3D files (embedded in FLAC) purchased from various labels, 5.1 PCM with metadata audio signals are detected by the Realiser A16.
