maxxevv
Are you trying to connect a balanced output to a single ended input?
Sounds like it to me.
hello there ..hope this is the best thread for my problem! I bought a 2.5mm to 3.5mm cable so I could use the "balanced" output of my Sabaj DA3 - supposedly optimised for the best sound - connecting it to my Topping NX1s, and the result was dreadful. Nothing but horrid disintegration of sound! (Yes, I pressed the buttons to switch outputs, and the readout indicated 2.5mm BAL). But dreadful resiult. And now, what's worse - reverting to the standard operation with DAC alone and UNBAL 3.5mm ouput, the device no longer woorks at all! NO audio will come through it, and it turns itself off in two seconds! Will NOT stay on... anybody experience anything like this? Somewhat reluctant to message the Sabaj people on Ali, as you only get second-hand messages from "R&D" filtered through whoever answers the message-box....
Don't quite understand what you're trying to do there.
Your Da3's 2.5mm output has R+, R- and L+, L-. So they are designed for your headphones / earphones left and right channels.
Your NX1 has a 3.5mm line in. Which has only 3 input signal lines. R+, L+ while the R- and L- share a line.
By plugging your 2.5mm TRRS into a 3.5mm line in, you are effectively shorting the R- and L- together.
I'm not the least surprised that it got burned / killed in the process.
Haha i have to tell you I don't know what that means ! I simply followed the directions given to me my other head-fiers on threads elsewhere, got the appropriate cable and plugged in ! And now my device no longer works!
You haven't understood correctly what others were saying before you made your leap of faith it seems.
