DjBobby
https://bit.ly/2BHszwoWhat is the iq, can you send a link?
I also have another battery powered DAC and I never use it because when I need it, the battery is low. I think a battery powered DAC only is an option if you use it every day and therefore also charge it every day.
I‘ve received the Meenova Lightning adapter and can confirm that the Da2 works with my iPad.Does anybody know if this cable works with Sabaj Da2 and iPhone?
https://www.aliexpress.com/item/Mee...ad-iPod-Chord-Mojo-Hugo-Pha3/32856542392.html
That's my impression with most of the ESS Sabre dacs. It works better with darker and warmer headphones.Wow, I'm actually quite disappointed, the Idea/Da2 is so cold and bright compared to my XtremPro X1, which is warmer and more detailed, and it's also much cheaper. This sounds so much like the DragonFly Black, almost just bland, and the only positive thing is the cleaner audio and vocal projection but it doesn't sound as detailed, just more ear piercing and focused on making the vocals more present, if that makes sense.
The X1 has a ES9023 in it, it's so far the most enjoyable unit with a Sabre chip I've tried out, and yes it doesn't sound the best with my bright AD700X, not bad but it sounds like something is missing in the mid range, it wasn't as bad with my cheapy bassier JLab Intro. I ordered a Da3 and I heard that sounded like it has more body than the Da2/Idea. We'll see.That's my impression with most of the ESS Sabre dacs. It works better with darker and warmer headphones.
The outer isolation of the Meenova Lightning adapter is already broken, so it will fail soon. I would not recommend it.I‘ve received the Meenova Lightning adapter and can confirm that the Da2 works with my iPad.
hello there ..hope this is the best thread for my problem! I bought a 2.5mm to 3.5mm cable so I could use the "balanced" output of my Sabaj DA3 - supposedly optimised for the best sound - connecting it to my Topping NX1s, and the result was dreadful. Nothing but horrid disintegration of sound! (Yes, I pressed the buttons to switch outputs, and the readout indicated 2.5mm BAL). But dreadful resiult. And now, what's worse - reverting to the standard operation with DAC alone and UNBAL 3.5mm ouput, the device no longer woorks at all! NO audio will come through it, and it turns itself off in two seconds! Will NOT stay on... anybody experience anything like this? Somewhat reluctant to message the Sabaj people on Ali, as you only get second-hand messages from "R&D" filtered through whoever answers the message-box....
Haha i have to tell you I don't know what that means ! I simply followed the directions given to me my other head-fiers on threads elsewhere, got the appropriate cable and plugged in ! And now my device no longer works!Are you trying to connect a balanced output to a single ended input?
