SMALL (Porta Pro-sized) bassy, closed headphones?
post-8025429
Thread Starter
Post #1 of 9
cactus_farmer
Hmmmm...
As title says really.
Looking basically for a closed version of the PortaPro's. Those PX200's looked like they might fit the bill, but apparently they're pretty neutral-sounding...
post-8025501
Post #2 of 9
soundstige
Something in the Sony world will probably suit the bill. They almost always lean towards clear and bassy for their modestly priced offerings. The JVC flats are supposed to be excellent too, for the price.
post-8025647
Post #3 of 9
JK1
The JVC Flats HAS160 has a decent amount of bass, however I wouldn't call it a bassy headphone. The JVC HAS650 plenty of bass.
post-8026438
Post #5 of 9
soundstige
I guarantee it's more than neutral. It's probably on the level of PortaPros, they're not really the pinnacle of quality, rattling bass.
post-8026576
Post #6 of 9
Astrozombie
L.A.
L.A.
Porta-pro is pretty bassy already IMO, JVC Flats no way, maybe you can try the HTF600 and use them on the go?
post-8026621
Post #7 of 9
Coq de Combat
The AKG K450 and K518 are rather bassy. At least the K450 should be same size. The K518 just slightly bigger..
post-8026977
Post #8 of 9
JK1
The JVC HAS160 has decent bass, however it is not extra bass. The bass is in proportion to the other frequencies and not exaggerated. The JVC HAS650 has much more bass than the HAS160.
post-8026979
Post #9 of 9
JK1
