Arkham00
- Jul 27, 2010
Hi guys,
I'm quite new to this world, and I'm reading around this forum since some months.
I've learned a lot of things and I think I made up a clear idea of what I need.
I came from sleek sa1 and sound magic PL30.
I liked very much the sleek that opened a new world to me, but the more my ears get used with it the more I feel that I need smtg better ... weird.
PL30 didn't impressed me very much and now I use it as a backup iem.
So I want to go toward high end monitors and try out an armature phone as well.
I narrowed my choice based on what I could read and what I need :
a detailed and clear sound, without losing naturality
I listen to a great variety of genres, mostly heavy metal, jazz, folk/celtic, electronic/techno and classical, so I also need something versatile.
Anyway atm I'm more in a classical/symphonic period and moreover I'm learning how to mix audio recordings, so I need to really listen to the original sound of a piece of music to understand the mixing differencies.
I came up with these 3 IEM :
- q-jays
- etymotic ER4S
- Audeo PFE 112
But it's very hard to choose.
My gear is a rockboxed 5 gen Ipod, and a FIIO E5 amp.
I'm very attracted by the ER4S since it seems it has the most analytic sound, but sometimes it seems that is too much, and I fear to loose the pleasure to listen my music, moreover it seems it isn't a very comfortable iem and the cable is quite microphonic and very hard to manage. Is it really difficoult to wear it over the ear ?
I red that with a good setup (amp, lod etc...) we can have a more natural sound from it, in this case what can you suggest me ?
Q-jays seems to be the good compromise, quite versatile but very detailed (men! 2 armatures!
), and very comfortable but I never red about its isolation quality, and this is important to me, I take every day a very noisy train to go to work.
Also, I see they are shipped with normal silicon tips and foam tips, I like very much the 2/3 flanged tips, and I don't know if the foam could be good for me, I only experienced the soundmagic foams and are very very bad to me, but maybe is because soundmagic is cheap... can I expect smtg better from different foams?
PFE also seems to be quite detailed and confortable, and I can't find any big pro and con for it, so maybe could it be the right choice ?
thank you guys
- q-jays
- etymotic ER4S
- Audeo PFE 112
thank you guys
