The other main difference between the Holo and Singxer driver is the ability to play native DSD vs DoP. That may not matter to people but for me I use HQP and wanted to only use native DSD.
A word of advice on the drivers. Since both the Holo and the SU-1 are XMOS based devices they are functionally equivalent. As such, you do NOT want to have both drivers installed simultaneously. I did this once and got my PC very screwed up!
I spoke to Tim @ Kitsune and he recommends that you use Holo driver over the Singxer driver. The Holo driver is "signed" and tested. The SU-1 driver is essentially a generic XMOS driver.
I am fairly certain the driver has zero bearing on which DSD sample rates are supported. ....that's the job of the devices firmware, not the driver installed on the PC.
I'm a bit confused with using either the SU1/Holo driver? Prior to adding the SU1 to my chain MBP>Holo my MBP MIDI set-up recognized the Holo which is what I used as the "output audio". When I added the SU1 to my chain MBP>SU1>Holo I only had the choice of using the SU1 driver in my MIDI set-up. It seems the SU1 driver over-rides the Holo driver? I'm under the impression on a PC you could choose which to use one to use as the "output audio" as the driver, but on a Mac you cant? Am I missing something?
No, there is no driver to install on a Mac, so I guess it is different from a PC having a driver choice.
Also, being I don't need to install a driver for the Holo on the Mac, I don't recall any settings for latency? Maybe this is only a PC option as well? All of my options are done via JRiver. Maybe I'm missing something?
I'll just run my Mac the way it is without partitioning it to use the Holo drivers.
I've never used a PC for audio before so thanks for the clarification as to why I don't have these setting. I just thought I may have been missing something.
So does that mean Letner was willing to make a DC input one? In the past when I have asked him he said he had no plans for offering a DC input version. So I assume he is going to just add a DC barrel socket to the back?
Since I2S is best suited to short runs, I decided to invest in a quality 1.5M WireWorld AE$ cable to try out.
Out-of-the-box I can't hear an audible difference between the two. It will require more than just casual listening to discern any differences.
In the meantime, the only "disadvantage" of using AE$ is that it doesn't support native DSD. It requires that I configure my player to use DoP (DSD over PCM).
That's not really that big of deal as I've been perfectly happy using for DoP for years. It would be nice to go "native" and avoid the processing overhead of packaging DSD into a PCM stream.
@T Bone I wonder if there is any audible difference between a super short HDMI cable and a longer one? I think this weekend I will throw in one my longer HDMI cables I have laying around and compare it to the 0.3m one I am using now with the Spring and SU-1.
@T Bone
I have the same question. I am actually on the hunt for a quality "shorty HDMI" to add to my inventory. (You can never have too many interconnects!)
My SU-1 & Holo are over 1M apart, but for testing purposes, I could temporarily move the two closer together and see if it makes any difference.
