headphones se indeed not perfect, but good, true. But rca outputs are clean as the XLR, for sure.Arrives today, I'll need some time. I'll be testing it with HE-6 and in my 2ch setup. Unfortunately it looks like SE performance is not good, which my 2ch is RCA so conversion there will be bad so it's all down to headphone performance for me. This'll be compared to Jot2.
correct, same here, single ended I was missing high gain, but then went balanced cable and it is now plenty plenty loud in low gain.Tonight's session went well, no fatigue. Great amp! The class A of chip amps, though I'm unsure it's true class A due to low heat. It's not constant heat output. Single ended is low power for sure on my headphone, but still sounds clean enough. This amp is a home run!
