Simple but successful Mod on HE-400s
Apr 1, 2013 at 2:32 PM Post #46 of 52
I wanted to use this one (http://turbulentlabs.com/grado-black-manta/), but I don't know how to do the mod. I don't think I should glue it, I think velcro is the best way...
Any advice?
Apr 1, 2013 at 9:34 PM Post #47 of 52
Any advice?
Are you just wanting to use it as extra padding? or replacing the headband as a whole? Sorry If I miss understood. In my pictures you see the type of velcro I used. Its pretty basic. Just put pieces on both the pad and the headband on the headphone and attach the two. Not sure how much extra comfort that headband you posted would provide. It also seems pretty small. It may just be the picture though.
Also you will have to use the sticky adhesive on the velcro to attach the pieces, so there may be some sticky-ness if you remove the mod, but it can easily be wiped off.
( I have seen other mods for some headphones where people use string to attach extra padding, but looks kinda ghetto. There is also the option to stitch the padding into the headband, but that is more permanent, and takes a handy touch. ^_^
Dec 26, 2013 at 8:45 AM Post #50 of 52
Agreed with all the above. The he400/500 fits me on the tightest setting, so the added material would be dual purpose. Nice post kcxsmaker!!
Dec 30, 2013 at 6:54 PM Post #51 of 52
great DIY suggestion. For me personally, this specific mod w/ the HD600 headband cushion hasn't worked for me as the 4 bumps of foam actually increases the pressure points to specific regions on my head while the stock headband distributes the weight pretty evenly across the top of my head.
picture of new personal DIY attempt: called ghetto mod using cut up memory foam packaging cushioning (1in thickness) + twist tie
http://www.head-fi.org/t/604583/hifiman-he-400-impressions-and-discussion-thread/15540#post_10113475
