- Jun 26, 2001
A real good test of the quality of the bass on these for me was the nightclub scene on 'as above so below', that really gives them a workout and they come back at you asking for more
Have been reading up on the SE846 threads and decided to get one based on the reviews. Received mine today and have been listening to it for 3-4 hours now.
Unfortunately, I have been used to my Grado PS500e and these $1000 phones while sounding decent are nowhere near my PS500es'. The mid-range sounds pretty decent, but lacking in the lows and highs. For e.g acoustic guitar tracks don't seem to have the punch due to this. Soundstage seems ok.
Haven't used any quality IEMs in a while, is this as good as it gets with IEMs?
I am assuming these will get better after burn-in, but by how much??
Chodi said:.Impedance mismatch and you get no bass even with a good seal.
Have you looked at the SE846's impedance response? A high output resistance actually leads to more bass (and highs). You will get a loss of low bass withe the low impedance Shure if your source has got wrong imensioned decoupling capacitors (e.G. Cowon, Colorfly C4).
Ok lets agree that source impedance counts. The general rule is that the impedance of the earphone should be at least 5 times that of the source output. Some say even more like 8 times. To be safe for most very low impedance headphones you are generally best with a source output of 1 ohm or less. That is why the vast majority of portable source devices and amps are rated at 1 ohm or less.
Worked on the seal a little more and that seems to have improved the bass.
