Earbones
- Dec 21, 2013
wat.
You can't amp a SE846 to its full potential, but with the Audeze you can make it sound so much better than the 846. I refuse to buy a TOTL IEM because they're so easy to lose.
I've listened to the LCDX on an AK240 for 2 hours straight, and the 846 probably for 20 minutes. While an IEM is good, it will never be as good as a headphone. The Audeze reveal everything about the recording, wether its in a small booth, a concert hall, and you don't even have to listen intently. Where the 846 may be portable, it's 2cm away from your ear and therefore can never be as good sounding as a full size headphone.
I think the only way an IEM could be better than a headphone like the Audeze if you used a type 6 litz cable with dampening cores (to completely silence microphonics and keep the sound constant through the cable), and use the same sort of material a full size headphone uses. Shure comes close with their foam tips. You'd also need something like the 240 for the 846 to get close to an Audeze, which at the end of it is 3x more expensive than the LCD2 in my country. Even my headphone store, Jaben, admits Audeze is totally better than the 846, and that the price is overkill. But people will buy it for portability, and that's where it goes wrong.
The full sound felt fake to me, like it was unnatural. Soundstage is very good for an IEM, but after hearing what the LCDX can do with a 240, there's no going back to IEMs. I was going to buy the 846, btw.
On the bass- yeah, mid end - near high end IEM bass sucks big time. Putting a dynamic driver in spoils the experience too. The only IEM I know of with REALLY good bass is the Heir 3ai.
Okay.
