xaddictionx
- Jan 18, 2013
Does anyone use the white triple flange tips with this? Ive been using them for quite a while now and have cut off the inner most flange because it was too deep. I think i might have lost some intimacy as well as isolation but it was digging too deep and was actually painful to insert all the way.
Anyway, my question is for those who have been using them, how do you clean these?
Mine are starting to turn yellow and the outermost flange that provides the best isolation is actually beginning to warp which hinders the tight seal. Any suggestions?
Also, after using these, I'm sort of desiring a combination of all options.
Id like the deep rumble of the black filters with the brightness and spaciousness of the white filters while having the isolation of the triple flange tips with the soundstage of the gray olives. I don't want to use the foam tips and get used to that sound because I feel the foam tips wont last long as complys for me only last a few weeks.
Have you tried out the Westone Star tips yet?
